Can i wire a fm transmitter in my pc help need
  • Can i wire a fm transmitter in my pc help need
    hi i have got a fm transmitter that can run off battery or from a 12v in the car but i would like to now is there a way i can run it from the power supply on my pc as my pc does not have a 12v port and it eating alot of batterys i hope it can be done.
    thanks alot.
    Yes the yellow and the black right next to it on the drive power connector are 12v power and ground. Yellow being + and you guessed it Black being -. Hope that helps
      ok cool do you have any pictures or diagram so show me how to do this thanks you
        If you take the power connector that plugs into your hard drive or cd-rom you will see 4 wires. Yellow, Black, Black, Red. You want to use the yellow and the black right next to it. You will hook your transmitter red wire to the yellow and the black wire to the black.
          hi i will try it out and see if it works
          thanks you
