Picking up Aussie Radio? Also Good soundcard?
  • Picking up Aussie Radio? Also Good soundcard?
    Gday, ignore my newbness, but im still unsure how id go about connecting up an aerial to gain radio access through roadrunner? im in australia, and not sure how its being done?
    Im also wanting to run a decent soundcard to gaiun better audio through amps and speakers, can anyone point me in good direction of well made soundcards that can do the job? and worth the money? PCI i guess would be the go?
    Thanks for the time to read, Ryann,
    You need radio tuner hardware that will accept an antenna connection.
    I suggest searching the Roadrunner forums. There are several radio options available for RR users.
    How about the Wiki?
      I use the dlink DRU-100 for FM radio. it's not available from dlink anymore, but you may be able to find one on ebay if you are lucky. You can use a program called radiator to listen to your radio. Radio functions are integrated into RR
        Are there any similiar products to what dlink used to sell?
          not sure anymore. basically any FM receiver that uses radiator can be used in RR. You could also have a look at the TV tuner cards with FM as well. You may not use the TV function, but it might be the only way to get FM
            silabs usb tuner is available from farnell here in Australia. seems to be the best option at the moment regarding signal strength whilst moving. also it has a plugin available for RoadRunner. i dont have one yet but will order one soon!
            2005 Nissan Xtrail
            DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
            worklog
