Nano-ITX board with S3 suspend
  • Nano-ITX board with S3 suspend
    Hi everyone,
    I searching for new board because my VIA PX-10000(Pico) doesn't support S3 suspend... I need board which is:
    -Nano-ITX
    -Support for SODIMM 1GB DDR2 533
    -SATA HDD
    -S3 suspend
    -Windows Vista
    -res. 800x480
    So this is what I need. Now I have VIA PX-10000 and can't install Vista on it and S3 doesen't work...
    Which board is best for me?
    Thanks for any help.
    Bye, _Dejan_
    Considering that both the PIcoITX and NBAnoITX boards are both made by Via, I wouldn't count on S3 standby mode.
    Why on earth would you want to run Vista in teh car anyway?
    How about the Wiki?
      I would like use Vista because have hihbrid suspend so if go in S3 state do hibernate to and if voltage go under 11V power suply do hard off and when I turn it on then do hibernate... If voltage does't go under 11V do normal S3...
      Which nano board do you have? Im thinking about NX15000G...
        Nobody can't help?
          I never said I had a NanoITX board.
          Be patient. Not everybody is going to visit these forums in the timeframe you desire. It's arrogant to expect that the person who has the answer you're looking for is going to visit, see your thread and answer your question in the span of time you dictate.
          Be patient.
          How about the Wiki?
            Im find one seller who will test NX15000G board if support S3 suspend and Vista I will take it...
            Im thinking that you have nano board because you are answer on my question...
            So board don't need to be nano I must put it into case 14cm x 15cm... If VIA boards don't support S3 than can be any other with Pentium M processor...
            Because Im 2 months without carpc Im little impatiend...
            Thanks.
            Bye, _Dejan_
              May not help you any, but I thought it was a cool...
              http://www.newegg.com/Product/Produc...82E16883192022
              03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
              Carputer Planning |---------*|
              Overall Implementation |---------*-|
              (Stereo complete)
              Computer installed and working
                hi thanks for reply but is to big...
                I need max. 14cm x15cm I think this is 5.5" x 5.9"...
                Bye, _Dejan_
                  3.5" embedded biscuit PCs fit your dimensional requirements. The PCM 9373 I use is 145 x 102 mm. I do not know about the S3 capability, but it is at least another form factor you can consider.
                    Im look for this PCM 9373 but don't have SATA. And S3 is inportant if don't have it then I don't need it...
                    Thanks for your help...
                      bump...
