Dell dimension 2350 desktop... Any SMALLER cases compatible?
  • Dell dimension 2350 desktop... Any SMALLER cases compatible?
    Hey guys.. I was given a 2350 p4 1.8ghz computer. I pretty much have no use for it, but then i remembered. I need a carputer! Hehehe. So this is good. My question is, are there any cases that I can put that motherboard into? Or should I just rip it all out and throw it in a custom box? My trunk space is pretty small. It could fit as is but it would look too bulky and ugly.
    Custom is what I would do.... but the question is what you will do...
    TruckinMP3
    Read the FAQ!
      I will probally end up making a case.... does anyone know the format of the dell? atx, microatx, itx?
        Dell doesn't follow any particular formfactor for their SFF systems.
        It's their own formfactor, really, and follows no known standards.
        How about the Wiki?
          ohhhh.... ok thanks... so custom is what ill do. A wooden case should be ok, just have adequate ventilation basically
            My PC is mounted in an MDF box.
            You should be fine.
            How about the Wiki?
