Opus 150 and...
  • Opus 150 and...
    HI,
    I have an opus 150 and a mini ATX. I have decided to buy a case instead of making my own. What case works well with this PS?
    -B
    Thanks for asking... I want to know this too.
    I'm wondering if Opus can fit in VoomPc.
      Originally posted by maximaman View Post
      HI,
      miniATX? Never heard of such a thing.
      Do you mean miniITX or microATX?
      Not out of the box. Thee Voom cases are designed to fit an M1 or M2 and the dimensions are completely different. IIRC, the Opus 150 also has a vertical board, so it looks like an upside-down T.
      You might be able to fabricate a bracket or something to get it to fit, though.
      How about the Wiki?
        Where is it going to be located?
        Sound Stage
        Eclipse|MTX|Infinity
          I got the opus 150 and I had to go with a bigger case,wich is a good think for temperature problems.
          I dont regret my choice
          I'll find you the case specs....
          VmtSquad - I sold my soul to Honda!
          Final Install
          CarPC progress: 95%
            HUH? miniATX where did you buy it first time I hear it..
            please more details
              micro-atx case for opus 150w supply
              I use a micro-atx intel motherboard with the opus 150. I actually take the opus power supply outside of it case and mounted inside of my case. here are some pic of my case, and cases I sell.
              these cases are design to for opus 150 and I think the new 180w opus power supply. It has all the mounting hardware you will need. mounting for 3.5 hdd, power supply, three fans, usb ports and power in/outputs for hooking up external devices like usb hubs, external sound cards or anything that is 12v or 5v.
              https://www.facebook.com/hinnantdesign1
                this is what the opus 150watt power supply looks like outside of the case
                here is the pic of a 150 in it case when you buy one
