Onboard sound
  • Onboard sound
    Hi all,
    hoping some1 can help with this problem.
    I'm having problems with the sound on the below motherboard. I'm sure it's to do with the set up of some of the jumpers on the board. can anyone tell me which ones should be connected and which ones open to use the sound output on the back of the board.
    http://linitx.com/viewproduct.php?prodid=11227
    Thanks,
    Ricky
    uhhhhh....
    What are the problems you're having?
    It's a little bit difficult to troubleshoot a problem when you don't know what that problem is....
    How about the Wiki?
      Originally posted by DarquePervert View Post
      uhhhhh....
      sorry, I'm half asleep at the moment.
      Basicly getting no sound off the board through the jack output.
        Did you by chance hook up any front-side audio ports. for example, the Voom 2 case has RCA front side ports that use the jumpers on the motherboard. Hooking these up will stop the rear jack from working forcing you to use only the front ports.
        Did you get your problem solved yet?
