Hard Drive to Handle Extreme Cold?
  • Hard Drive to Handle Extreme Cold?
    Hey guys...I am trying to decide on which drive I want to use. I am looking at solid state drives to avoid any trouble that would be caused by vibrations, but even they have a minimum operating temperature of 32 degrees. Has anyone found a drive that will support lower temps?
    Define "lower"................
    Leonardo Da Vinci
      my compact flash and 3.5" mechanical both worked fine over the last week and its been between 10 F and 30 F here in MI.
      AutoPC v1 (Retired) - AutoPC v2 (in progress) -
        -30 deg F.
        Jan Bennett
          Thats -30 C to 85 C
          -22 F to 185 F
          PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D/i7 still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
            I have a regular 2.5 inch Samsung drive and it works above -10 celsius.
            Ampie Case
            256 MB DDR2 PC5400
            Xenarc 700TSV - VGA Monitor
            Intel D945GCLF Motherboard
            2005 Honda Civic
              Hi All!
              I from Russia. We use simple disks of 2.5". The hard disk can not start at temperature -25 but when the car stands on warming up about 10 minutes all will start normally. Excuse for my English.
                Covered here:
                Want to:
