Netstumbler for Wireless AP scanning. Works with DLink USB.
  • Netstumbler for Wireless AP scanning. Works with DLink USB.
    I just tried Netstumbler for my car and it works sorta.
    My Dell laptop has a Truemobile 1150 MiniPCI internal wireless card. Netstumbler works perfect with it. When it detects a connection it makes a little sound to alert you.
    My CARPC has the DLink USB wireless adapter and it detects wireless networks but doesn't make the sound when it detects one and also for some strange reason, it does not display the Channel number.
    Anyone else use this with USB?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    If i recall correctly, netstubler is built specifically for a couple of different chips in wireless cards. Last I checked, Dlink cards didnt use a 100% compatible chip. But, I could be wrong.
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
      I tried using it briefly the other day with my Orinoco silver and it seemd to work OK. Displayed a few networks in this apartment complex but I could not connect to any of them due to WEP encryption.
        SuperMatty, you could'nt connect to any because of WEP?
        Can't you crack it?
          NS works great with my Linksys WUSB11 w/XP. Had to enable midi output under options to get sound. Had my first wardriving experience this past sunday, mooched some internet access, then ran home and double checked the security of MY AP.
          97 Dodge Ram 13.8" touchscreen/DVD/GPS/TV/FM
          Some pics & details here
            As I understand it, NetStumbler doesn't work with Prism based cards (early D-Links, Linksys, etc.) but does work with Prism II based cards (later D-Links, Linksys, etc.). I have always used it with Orinoco Turbo II cards, and it works great. Plus, they have such a nice jack for an external antenna...
              so anyone got a extra usb wireless card they wanna get rid of so i may join in the stumbling
              WINNER!!!!
              run-on sentance comp 2002!!
                No, but if you look on eBay you can find the Dlink I got for 60 buks or so.
                I donno what the .000000000002 cents will do though for the purchase.
                  i have yet to get the wusb11 version 1 to work with winxp, not like i'm trying hard I have an Avaya Gold and a WPC11 to use.
                  Just would be nice to have the usb guy working.
                  1997 Jeep Wrangler Rugged Waves
                  Ebay Stuff For Sale
                    My DLink USB works fine with XP.
                    I did notice one cool thing-------------------->
                    If I install the old drivers on the CD, and use the new utility it automatically connects to all the networks it finds.
                    If I install the new drivers, then it seems you have to connect to the WiFi manually and then keep it in the list of your networks to make it connect automatically next time you are in the vicinity.
                    The USB Linksys should work easily with XP.
                      well i re-enabled SSID broadcast and it worked, damn thing won't work unless u have broadcast on, even if u specify the network name
                      grr!!
                      Ebay Stuff For Sale
                        Well finally, we can stumble withthe new NetStumbler. www.netstumbler.com
