VIA EDEN Boards and 10.4" Displays
  • VIA EDEN Boards and 10.4" Displays
    I have seen on this board that the eden VIA boards do not
    produce a strong enough video signal to run larger LCDs. Is this
    true?, Does any have a setup using a 10.4 " and a VIA? If It IS
    true will the problem be fixed when the New VIA boards come
    out? Any help would be appreciated.
    Aut cum scuto, aut in scuto
    Re: VIA EDEN Boards and 10.4" Displays
    WTF?
    My VIA EPIA 800 runs my Sony 19" 400PS monitor, and that has a really fine dot pitch on a really big screen, so that would need even more power wouldn't it?
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
      I can't imagine how the power of the video signal would relate to the size of the display... I mean, there's either a decent signal for display or there isn't.
        I have no idea where you got that from. This doesn't even make sense. The size of the display has nothing to do with the signal it recieves. The signal gets processed and the information is used to produce the image on the screen. If it can be used for a 6" display it can be used for a video screen in Times Square, or Tokyo..
        If you would, please point out the post where you found this misinformation so that confusion can be cleared up.
        aka Kumaneko
        "Don't make me moderate your ***!"
        Maxima of Doom - project thread - photo gallery
        mp3car system is currently FUBAR and finances do not allow for a correction of that situation
        Real computer hackers use a rotary cutting tool on their motherboard.
          I dont think it was signal strength, i think it was resistance. and it was a post by someone that couldnt get their denisk screen to work with their epia, but could on a fv25, so ended up going with the shuttle.
          -Nick
          _____________________________
          www.mp3vw.com
