Silab USB radio stopped working
  • Silab USB radio stopped working
    Hi,
    I have a Silab USB radio. It worked fine for a few months, but then all of a sudden the computer kept making the (usb device removed) sound and now when I plug in the USB radio, the LED inside is orange and the computer does not recognise that a USB device has been plugged in.
    Has anyone else had this happen?
    If so, what did you do to fix the problem?
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    I sent an e-mail to Silabs and this is what they mailed back:
    Hello,
    Sorry for the delay in answering your email. The problem you are seeing is probably due to flash corruption which means that the contents of the flash has been accidentally modified. In this case you should reflash the device.
    To upload again the flash with the correct firmware you will have to do the following:
    1. download the latest version of the FM Radio RD firmware from our website:
    http://www.silabs.com/tgwWebApp/publ...USBFMRadio.htm
    2. connect to the USB FM Radio (you need an USB Debug Adapter for this):
    - on the debug adapter's connector, the pin 1 is the one corresponding to the red wire or to the arrow on the connector
    - take the FM Radio board out of its casing
    - near the MCU are three holes which are the GND (written next to it C12), C2CLK (written R18) and C2DAT (written C17). These holes can be used to connect to the device using the debug adapter as follows
    - connect pin 9 of the Debug adapter to GND (hole with C12)
    - connect pin 7 of the debug adapter to C2CLK (hole with R18)
    - connect pin 4 of the debug adapter to C2DAT (hole with C17)
    3. connect the USB FM radio to the USB port and the USB Debug Adapter to another USB port
    4. open the silabs ide and press the connect button. The device should get connected
    5. extract the zip file you have downloaded
    6. open the F320_FM_Radio.wsp project with the silabs ide
    7. compile the project and download it to the device.
    8. disconnect all wires and everything should be working properly
    You will need the full keil compiler to compile this project since it is bigger than the standard 2K. In case you do not have the full keil compiler, I have attached the compiled hex file which can be uploaded to the MCU as is.
    Please let us know if you have further questions.
    So they want me to buy a programming debug tool and reflash the USB radio. Surely when you buy a product you shouldn't have to do this?
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
      Well, the silabs usb radio is just sold as a demo unit for the silabs chip in it. It's really just meant for developers
        Yeah I know. But after re-programming it, still not getting it to work and having an e-mail conversation with a guy at Silicon Labs, they said it was a hardware failure and going to send me another one.
        All Good!
        7" Lilliput
        120Gb Sata drive
        1GB RAM
        (Always tweaking!)
          It should be. Hex file.
          Hello,
          It should be. Hex file. You can send or project with hex file. Tried to compile an264sv but after compilation does not work. thanks in advance.
          mikrosystem@mail.ru
            mikrosystem@mail.ru
              mikrosystem@mail.ru
              me too.
              Its Strange things.
              Try Convert DEC to BIN.
              https://silabsradiodll.googlecode.co...ig%20Beta2.zip
                me too.
                Its Strange things.
