Info needed about Ibase motherboard
  • Info needed about Ibase motherboard
    I want to upgrade my CarPC and now I'm able to buy some 2nd hand hardware.
    Main piece is a Ibase MB896 motherbord wich has a Intel P4 mobile 1,73Ghz already installed.
    First question: Is this a good motherboard , and will it run better then my former VIA M10000.
    Second question: Will a M2-ATX 160W be enough to power up the board, HDD, BT dongle, 4 different USB devices (touchscreen,HQCT radio,USB OBDII and a USB switch) and a 7"touchscreen?
    My M1-ATX does this without any problem.
    I wonder if this will be a good upgrade? main reason to do this, is that I want to be able to show AVI movies to the kids instead of converting them all to MPG, and also want more total speed.
    System will 95% of the time wake up from hibernation , so boot up speed is not really a issue.
    Gods right foot!!
    Renault Grand Espace 3.5 V6
    this thread should help. http://http://www.mp3car.com/vbullet...ome-input.html
    while you're at it, do you have any picture of your install I have an ML320 and plan on installing a carpc in it. I want to know what screen you're using and how it looks
      Here you can see my system.
      Screen attached to part of dashboard:
      Back view of installation:
      Now installed in the car:
      Home made casing:
      Now IN its final place:
      System running using RoadRunner and skin from Mauri:
      I just love this skin, but would like to upgrade in the future to a skin that looks like the one used on the new C-Class mercedes:
      Hope this will help you
      I dont know what the shipping cost will be but my former system is up for sale.
      (M1000 VIA-512mb DDR-PCI riser-4.1 chnl soundcard-M1-ATX power supply-Belkin Bluetooth dongle-40gb 5400rpm Harddrive full of muziek , movies and Roadrunner already installed)
      I'm asking for this all just $300
      Gods right foot!!
        sorry can't help you with your question.
        how did you cut the small holes (for connector plug) on the mdf board?
        it looks so clean.
        and did you used carpenter glue to hold them together?
        dsatx in voompc 2 case <HERE>
          Case is al glue together. I made the holes just bij first drilling them and then file them until they look like this
          Gods right foot!!
            IBASE MB896 - Recommendation.
            I have had the Ibase card running in my Red Vette for almost two years and it is a reliable work horse. The only problems that I have had is one hard drive developed bad sectors which is not the fault of the MB board. I have 1.4GHz Pentium M and went down to 512MB or memory from 1GB just to improve the wake from hibernation time. Going to a 5400 RPM drive also made a big difference.
            Check out my web site for the details on my install.
            Neil
            neilhart
            aka Neil
            My Domain is www.sfba-corvette.com check it out!
              Nice setup. The motherboard you mentioned will be a lot faster. The M2? Not sure...you will need to find out how many Watts the CPU draws...
              2006 Lancer Evolution IX MR In-Dash PC Project - WIP
              Planning:
              [----------] 100%
              Purchasing:
              [----------] 90%
              Installation/Fab/Assembly (Revised v2):
              [----------] 90%
                And what about if I use the M2-ATX to power-up the board plus my touchscreen.
                And use my former M1-ATX for the harddrive, both 7" screens on the back, and all the USB devices (radio, OBDII reader, GPS ) and case fans.
                Will this work?
                Gods right foot!!
                  Sure. Just pay attention to wiring.
                  Planning:
                  [----------] 100%
                  Purchasing:
                  [----------] 90%
                  [----------] 90%
                    I was thinking about splitting the cables comming form the battery to provide both supplies from power.
                    And of course also the ignition line. I just want both power supplies to start at the same time.
                    Thinking about this, best thing to do is to make sure that board and HD are on the M2-ATX.
                    That way the system will always start without any problem
                    Gods right foot!!
                      The ignition wire will signal the PSUs to start up so if you splice that you should be OK. Pay attention to proper wiring techniques and proper gauge.
                      Planning:
                      [----------] 100%
                      Purchasing:
                      [----------] 90%
                      [----------] 90%
