Screwy Motherboard.
  • Screwy Motherboard.
    dunno if i can explain this right but uhh i think i shorted out the startup pins on my motherboard. like using a power button the motherboard wont start up.. The only way to start it up is to jumper to pins where the power supply connector plugs into the motherboard. Will this short the psu??
    The way i the mobo stopped working is on the mastero shutdown controller, i took the green wire and spliced it into the green wire on the atx power connector.
