intel 1.33 ghz mobo fast enough?
  • intel 1.33 ghz mobo fast enough?
    Hi is the intel itx celeron 1.33ghz mobo fast enough for a carputer ? for running streetdeck etc ? i know games are out of the question , but for dvd playback i think it comes with sis graphics , or is the via 1.5 a much better board ?
    I have a VIA 1.3ghz/w 512MB ram board and it works great. It can play videos and simple games. Haven't tried any advanced games yet. I use the RoadRunner(Free) with DigitalFX skin(Free). It can do navigation + music at the same time with no problem.
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
      ive got one of them and is a great little board, throw 1GB of ram on it and its fine
      i use roadrunner and nRoute at the same time with no issues.
      i did a standard install of win XP pro with sp2 initially and it runs well.
      i am going to do a reinstall with a stripped down version of XP (mostly drivers removed) when i finalise my install and finish tweaking software.
      get the one with sata plugs if you think you may need that.
      and there is a version with a cpu fan, and without. get the one with a cpu fan
        cheers guys its nice and cheap to lol thanks!
          I guess I failed to mention I run TinyXP. Not sure how it does with full XP.
            You may want to check the MP3CAR.com store first. I do not think the board is compatible with streetdeck. It is the video chipset that is the issue I believe.
            I run 2 of these boards in my cars and they work great with every other frontend.
            The Car 2005 Scion xB
            The Truck 2004 GMC Canyon
