IDE to Mini IDE Question - Help Please
  • IDE to Mini IDE Question - Help Please
    I need help identifying the correct installation of my harddrive. The IDE cable I have 44 pin to 40 pin can plug in either direction. I know from experience that the wrong way frys the harddrive. Can someone please identify the right way? I cant afford to fry another harddrive.
    Option A
    Option B
    Fixinstuff
    Been there, done that, replaced it with a smartphone.
    Scott AFB, IL
    Do you have a pin-out diagram for the motherboard and for the drive? If not I would strongly suggest you get those docs.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
      does the hard drive have a pin missing on the bottom row of pins?
      and what brand is the drive?
        Check the adapter very carefully. It usually will say which is up and down. from experience with the top of the hard drive facing up and the 4 pins that are kind of seperated and not used to the right of the drive with the pins facing you. The power adapter should go to the left. Here is a picture of mine.
        Sorry for the blurry images, but I do not know how to turn on the Macros feature on my phone....
        1X Ainol Novo Flame Tab
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1X 7 inch motorized Screen
        1x Win 7 PC
          Yes, The problem is the cable doesn't, which allows it to plug in either way. The harddrive is Hitachi, bought it here.
          Fixinstuff
          Scott AFB, IL
            Originally posted by HiJackZX1 View Post
            Check the adapter very carefully. It usually will say which is up and down. The power adapter should go to the left.
            Thanks for the pictures. I will also try to find the documentation for the hardrive.
            Fixinstuff
            Scott AFB, IL
              Does the cable have a little red line down one side? That usually indicates Pin1. Check the drive for a little "1" printed on either side of the connector.
                Learn something new every day. Yes it does have a red line. Thanks for the input.
                Fixinstuff
                Scott AFB, IL
