Autopage 720 car alarm - trying to disable dual stage shock sensor
  • Autopage 720 car alarm - trying to disable dual stage shock sensor
    1st off how old is the 720 model, if anyone knows? I couldn't get much info from the main site. http://www.autopageusa.com/t_inside....ts&cat_id=1001
    I see the 315 & the 220 advertised as new. How is their number scheming done? Wouldn't you go over 720 and up?
    Anyway, main question: I disabled my mounted shock sensor [sucked ***, and went off on loud bass from cars, UPS/FedEx/garbage/etc huge trucks]. The knob to lower sensitivity did not work, so it's unplugged now.
    But once in a while it still goes off, is the 'dual stage shock sensor', also contained in the main alarm component? How do I turn that off?
    moved to general hardware since this has nothing to do with hardware development...
    Jan Bennett
