(Problem with vita Ultimate) USGlobalSat BU-353 p
  • (Problem with vita Ultimate) USGlobalSat BU-353 p
    I purchase The USGlobalSat BU-353 , I install the drivers from disk and it wouldnot recognize the port and SD start the navegation Like I was in motion from swanson Cali, I try to stop route it woulnot stop , try to clear rout it clear but that didnt stop the moving on Nav, I disconect the receiver and still was running the route, I manage to access the setting on SD and disable the Navegation, Can any one tell me where I can find a GPS receiver that WILL work with Vista Ultimate running SD, and yes I did went to the Manufacture website and download the drivers and became worse, I got a blue screen and crash my system, so I nmanage to uninstall the GPS.
    any help on this.
    Thx
    I've been using the USB GPS receiver that came with Microsoft Street & Trips 2008 together with Vista Ultimate, and it works without any issues. Tried the same unit with XP Pro SP2 and kept getting BSOD's after 2 minutes of using the GPS.
    not sure what you meant by "running SD"
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
      Thax.
      I will try on xp and see how that work, I am thinking to go back to XP in stead of Vista.
      (SD) streetdeck
      I was refering to setting on SD
        I'm running the BU-353 on Vista on car pc and works great. Also tried it on my desktop which is Vista Ultimate and works.
          I am also running a BU-353 in Vista 64 bit Ultimate (iGuidance though), without problems, although since I now have a bluetooth dongle for other stuff, I have decided to ditch the BU-353 and go with something like a Holux M1200 that I can also use with my pocket PC phone on the go.
          -C
            thx guys
            I got it to work.
            weeeeeeeeeee!!!
            now i will be working on my bluetooth, wish me luck, lol
              SD mp is motion
              I have USGlobalSat BU-353. I turn off my computer and later when I turn it back on the gps LED is not on. Got no signal. I try a different gps and it shows that I was at Swanson ave,NV like i was driving around. I turn the computer off and back on and it still dos the same thing. How do you guys fix this problem? thanks
                Ditch the globalsat and get a blue tooth dongle and a blutooth GPS.
                I just got the cigarette lighter powered Holux GR 239 and also have tried the battery powered 236 Holux, and this solution seems to work great.
                  BU-353 motion problem
                  bought a new USG BT-359 BLUETOOTH GPS. WILL LET YOUR GUYS KNOW HOW IT WORKS OUT WHEN I GET IT.
                    You've selected the gps simulation.txt for your gps port.
                    I was stumped on that one for a few hours too, and frustrated that I could not get into the settings to change it since SD thought I was in motion.
                      Originally posted by zodiaco View Post
                      thx guys
                      I got it to work.
                      weeeeeeeeeee!!!
                      What did you do to get it to work?
                      http://www.sounddomain.com/ride/2045209
                        BU-353 blue screen vista fix
                        I found an older driver that works in Vista. It seems to be stable so far. No blue screen yet. With the newer drivers from the cd I would get a blue screen around 10 min or so of running garminpc and roadrunner. Here is the link and I hope it helps others. It has drivers for almost all OS's.
                        http://www.usglobalsat.com/p-57-br-355-gps.aspx
                        Reggie
