Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
  • Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    This is the new "Atom" processor as dubbed by Intel to kill Via and their product line
    just curious if anyone has tryed this combo processor is a Intel Atom 230 @ 1x 1.60GHz (Silverthorne 45nm) and supposedly unlike the D201GLY2 which runs the processor at around 20 wats this one runs it at 2.05W and its only a few more dollars then the D201GLY2
    Im interested in hearing if anyone has tryed this combo yet and how its working....
    This is the one being sold by http://www.cartft.com/catalog/il/934
    and these are the specs
    Name D945GCLF
    Form Factor Mini-ITX Mainboard
    CPU Intel Atom 230 @ 1x 1.60GHz (Silverthorne 45nm)
    Chipset Intel 82945G (ICH7)
    L2 Cache 512kb
    Graphics Intel GMA 950
    Memory 1x DDR2 533/667 RAM
    Power 20 Pin ATX, P4-connector
    Connectors (rear) - 2x PS/2
    - 1x Parallel
    - 1x D-SUB15 (VGA)
    - 1x RS232
    - 4x USB 2.0
    - 1x LAN 10/100MBit
    - 3x Sound (Line Out, Line In, Microphone)
    Audio Realtek High Definition Audio
    Connectors (internal) - PCI
    - Audio
    - 2x USB
    - 2x SATA
    - 1x IDE
    Included - D945GCLF Mainboard (with 1.6Ghz Atom CPU)
    - I/O ATX rear plate
    - SATA cable
    - IDE cable
    - Quickstart-Guide
    - Drivers CD
      freight would be almost as much as the board itself for me.
      bring on the world wide release
        it seems very nice i wanna see what VIA and nvidia got in store tho well see
          [snip]
          I just did an online chat with their online sales guy, Benjamin (IIRC) and they DON'T have it in stock yet.
          Here in the U.S., we've been told that the earliest we can get a sample is June, whatever that means, probably END OF JUNE.
          Adding insult to injury, we just got word from Intel that the D201GLY2 (Little Valley 2) is going end-of-life at the end of June (IIRC), which is a big bummer for us as we were planning to use thousands of those babies. I wish I were kidding. I'm not.
            [media]http://www.youtube.com/watch?v=rWFkRUOFVmM&feature=related[/media]
            Sounds like its slower then the celeron
            Cold weather mobo list: Copy the list and add your board
            my hidden screen in action (youtube) , the worklog , RR Volvoskin
              D945gclf
              I am a new member here. I received the shipment from CarTFT this morning. But it will not be opened until I get home later this evening. I will post here my findings after I had some time to play with it.
                what i like to know:
                how mutch power for standby
                how long is the bois post (without the windows part)
                how quick to startup form scratch and suspend.
                Are ther hickups with suspend mode.
                Well you get the picture....
                  I don't see how that "kills" the VIA product line.
                  It's still a mini-ITX, and VIA's benefit those who are restricted by space limitations. Someone tell Intel that nano-ITX is the way to go.
                    I had some time to play with the board last Saturday and the experience was not good. I could not install linux/Vista/XP. All of them crashed during install. Only thing stable was DOS. May be, being new, I am doing something wrong. I treated it like a regular motherboard, added a keyboard, brand new SATA DVD drive, and a brand new SATA 500GB hard drive, and tried installing OS from a CD/DVD.
                      Stable Dos...
                      What kind of errors did you get, and when did they occur?
                      Did you power the CD-ROM from an automotive PSU?
                        hmm, i had somting simmular with my commell. Xp installed fine with the sata disk, but XP would't install on a ide. Turned out that the sata was ide 0 and ide was ide 1
                        XP wants to install on ide 0, you need to check the bios for that, so try a different sata port.
                        Hope you get it running
                          No not yet. I switch the SATA ports between DVD drive and Hard drive. Still no success. The BSOD bug check code is 8E. It happens immediately after all the files are copied to hard drive (probably when windows takes control and starts running the boot drivers).
                            8E its a bit out of my leage , but found a few quotes on the BSOD bug 8E:
                            Originally posted by Tedster
                            usually indicative of hardware failiure. Run memtest86+ from a floppy.
                            Originally posted by howard_hopkinso
                            Hello and welcome to Techspot.
                            Both your minidumps crash with 1bit memory corruption.
                            Go HERE (http://www.techspot.com/vb/topic35103.html) and follow the instructions.
                            It is true that some faulty ram can pass Memtest. If memtest gives your errors, your ram is bad.
                            Originally posted by SnowDog
                            The 8E error points at RAM problems. It's pretty unique for a STOP code in that it only points at RAM problems when you look it up! So there's a good start.
                            There are a couple of ways to diag it.
                            You don't say which PB model it is, but if it has two sticks of RAM you can try removing one of the sticks to see if the problem persists, and then swapping with the other stick likewise.
                            The other way is to download a RAM test utility and run that.
                            I can onely find 8E code with ram problems, so i think thats where you should look first.
                            ps win 2000pro installed without any problem on that system (its les picky about the ide number) so with win 2000 you have one thing less to look at.
                            Hope its the ram, and you can fix it / get it fixed
                              I have another RAM and will try tonight.
                              Thanks for the pointer.
