did I just blow my Mobo
  • did I just blow my Mobo
    Hi all
    I have bought a new carputer based on the Jetway 1.5GHz VIA Motherboard. I tested it without the CD/DVD drive it looked OK. It atleast showed the Bootup screen etc and told me to insert a system disk. I powered down connected my IDE DVD drive from the desktop. Powered up and nothing shows on the screen. Fans etc are running so its not the power. I then disconected the DVD drive. Same thing happens, nothing shows on the screen. last time something similar happened on my desktop and the MOBO had gone. Please advice. I am using a 12VDC adaptor that has 2Amp Peak current. Using a normal CRT VGA display and its working fine on my desktop.
    this probably doesnt belong in GPS
      Hi all
        i have the SAME motherboard and experianced simular symptoms i belive that the bios fried becuase you do not see the POST (power on self test) screen i have ordered another bios chip and will have it this week i will let you know if this was the fix for me
        i believe i fried mine removing drives too, maybe this board "more" subject to electric shock in that area than most boards
        here to hopeing its jsut the bios for both of us
        PS a new bios cost me about 15$ ill get you a link if it worked for me they guy is super prompt and comminicated well, lets jsut hope it was the cheap fix
        MY build...a walk thru, finally getting to it
          dude double post, i just replied to you in the general forum
            Will wait for your response. Good luck
              Teething pains
              thanks dude. First post something is bound to wrong...or even double
                yeah man il get back to you asap!
                  ok i jsut got home from work, the new bios was in the mail
                  went straight to the work bench installed the new chip and....
                  it was still dead... assuming i had a dead board i tried to "fiddle" hahaha
                  with things and finally got it to work here are some of the "troubleshooting steps" that solved this issue since i was fiddleing im not exactly sure what fixed it but it got fixed some where inbetween these two steps
                  ok so with the power on take out the bios chip (be very careful its hard to get out and you dont want to crack it)
                  with power on plug back in the bios, turn off mobo turn mobo back on
                  (wasnt watching screen still in fiddle mode)
                  PLEASE TEST TO SEE IF SIMPLY DOING THE ABOVE SOLVES THE ISSUE
                  then there s a chip right below the bios (if you have the connections facing you video, keyboard mouse ect)
                  mine says fintek and has a picture of an ant on it haha
                  i started at the top right and slowly and softly "dragged" my tweezers over the conductor of the chip (hopeing to send a little shock to reboot the sucker)
                  then from bottom left to bottom right
                  looked at the screen and it was on
                  trust me i know this is not normal im a computer tech and by no means would i recommend what i just did with the tweezers i mean i figured the board was already shot so i didnt care if i got a spark or two (i got none ) but it solved my issue
                  just sharing the information that i have, will this be car pc number two or will it go towards a home media center pc, i have noo idea
                    Thanks dude
                    Can only try, will keep you posted when I get home.
                    ...hope it works for me two.
                    I googled FINTEK. seems like the chip is some sort of sensor controller and may actaully be providing some input to BIOS chip TEMp, Fans speed etc
                    its data sheet says it shouldnt be used for life support system due unguaranteed operation go to FINTEK.com.tw cant get info on what exactly it is maybe its because I am not such a techy
                      Yo Its me again
                      Thanks for your suggestions. They actually worked.
                      I only did the first part with the BIOs chip. Took it off, put it back on, Siwtch OFF and Switch ON, and there we are the Bootup screen shows on my monitor . And there I was jumping for Joy. All because of your brilliant suggestion.
                      I have since managed to install windows hooked up the progs and everything works, including the touch screen.
                      Now I have a mission in my hands to mount that monitor on my dash somehow, which is going to be a steep one. I am even thinking of saving up for a Full Auto In-Dash VGA with Radio & DVD etc. I dont see myself doing well with Fibreglass... I am hopeless with such things
                      Anyway... thats another story. Thanks for the TIPS. Iam a happy man right there.
                        Ohh Man Im Soooo Glad This Worked!!! Yay For Having Working Stuff Again And Not Having To Throw It Away!
                          hey man jsut checking up, still working? mines been powerd of fon the bench for the last week jsut seing if it was a temp fix or not
                            Originally posted by mabhiza View Post
                            Yo Its me again
                            You could always pay someone to do the dash fabbing for you. Depending on the dash, it may cost you about $150 to $250........ Go to the fabrication area and there are people that offer their services.
                            1X Ainol Novo Flame Tab
                            4X MK808b
                            3x Perixx Touchpads
                            3x 7 inch Screens
                            1X 7 inch motorized Screen
                            1x Win 7 PC
