Power on by Windows Media Remote?
  • Power on by Windows Media Remote?
    Has anybody tried using a Windows Media Center remote to power on a laptop? I think this might be a very easy solution to the power on/power off problem, to mount my laptop under the seat, and run the IR reciever under the dash. Then, I think I might be able to power it up by pressing the power button on the remote. Has anybody tried this?
    Nothing to say you cant as long as it supports wake from usb. And it would be power on, it would only work from S3.
    Also it wouldnt be as automatic and oem as a true SDC (shut down controller).
    1.9in x 2.9in -- 47mm x 73mm
      Yeah, but I don't know jack about soldering and electrical stuff, other wise i'd go that route. Is there any kind of SDC that doesn't involve wiring?
        You have to get to the power jack somehow. There is always a time to start learning.
        You could also do a WOL, but that involves even more soldering, just it is off-board.
          Yeah, somethin I've been meaning to get into. Just don't have the time right now.
            Turning on a PC (or bringing it out of standby) with a remote is not as easy as it sounds. There is a lot of good information at thegreenbutton.com about MCE and remotes.
            Your laptop may have a feature in the BIOS to turn on when power is applied. If it does, then you only need something to put it in standby. There are applications using the serial port for this.
            Kirk
