CarPC Slowdown - Computer its half its speed
  • CarPC Slowdown - Computer its half its speed
    This happened about 3 months ago... I have tried just about everything I could think of to fix this...
    Basically, like the flip of a switch, the computer seems like it slowed to half its normal speed. I have installed an extra 1024mb of RAM, I did the WinXP tweak guides, nothing has sped it back up. Diagnostics on the HDD and computer doesn't show anything odd.
    Anyone have any possible ideas/solutions as to why it would just slow down one day?
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
    are you reinstalled the win, or only tweaked it? always slow, or sometimes (overheating)?
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
      What seems slow? Booting, running Crysis, etc. What's the CPU load showing.
        Okay... Sorry was trying some different things.
        The load time is 2x or 3x its normal... I ran a disk defrag, cleared temps, cleared prefetch and rebooted, disabled every single addon that is unnecessary... Still.. She is half her speed.
        I even stuck an extra matching stick of 1024mb RAM... So it's up to 2048mb of MUSHKIN green line. I think it all started one day while driving down the road. I think I was heading out to see my fiance, we went to eat, and when it started back up it was slowed down.
        I have wifi disabled unless I select to connect, hrmm...
        Jim
        2008 Honda VTX1800N
          What frontend are you running on your system.
            I got it! You switched the power button from hibernate to shutdown.
            Bootperf can show how much time is being spent on what during load, but I'm thinkings it's HD errors. I've been wrong about that before though. You can use HDTach to check the overall performance and performance across the drive.
            Opps, it's called BootVis
              CentraFuse... It is something Windows has to be doing.
              I have streamlined all of the services, only the essentials are on boot up... Windows or the HDD... Windows takes a good 45s to boot up. It used to take about 15s to get me to the windows desktop. From there, it takes another 45-60s to load up centrafuse.
              Im about to just do a complete format and reinstall. If that doesn't work I will just rebuild the carpc.
              It's not just programs loading... Its everything. The whole thing is slow now. If I pop open netstumbler, it's like I am loading Adobe Photoshop CS2. What once was a simple program to operate is now a enormous task. I'm thinking the HDD is failing.
              Jim
              2008 Honda VTX1800N
                If you go under our computers power settings and set it to hibernate and your problem is solved. I am running centrafuse and from start up to music playing it takes about 10s you should really try that approach it was suggested by the good people here on the furoms before hibernate I was going from a freash start also and let me tell you 67s from system start to desktop but with hibernate my problem was solved.
                  Well... Hibernate will alleviate that problem, BUT the issue I am having mostly is like sometimes music video starts to play it'll get laggy. Like it is not processing or reading the information as well as it could be.
                  Jim
                  2008 Honda VTX1800N
                    It sounds to me as if you are having some sort of windows problem if you havn't already done it I would do a fresh install of windows and reinstall all your apps with 2 gigs of rams you shouldn't be having this problem unless it is windows related.
                      Originally posted by BIGGKATT01 View Post
                      ...with 2 gigs of rams
                      What? Why on earth would you need that much for anything? XP runs fine with 512Mb. If the PC ran fine earlier, a RAM upgrade is not a solution, it's just delaying the problem.
                      I'd suggest Ghosting the drive to back it up, then reformatting the disk and re-installing. It sounds like either a Windows developed problem (is svchost.exe devouring huge amounts of memory?) or the hard drive is on its way out.
                      http://sticksout.blogspot.com
                        Check out Sysinternals Suite from Microsoft (they bought the company and haven't boogered up the utilities ). It has some great utilities to see just what is going on "under the hood."
                        In particular, try the Process Explorer (ProcExp) to see the resources evfery process and process tree is using.
                        Another utility in the suite, AutoRuns, will show everything configured to start automatically at boot.
                        Many of the utilities are command line programs but some (like ProcExp) are Windows programs.
                        Thanks,
                        Dan
