Two serial devices only one works?
  • Two serial devices only one works?
    I have a memorex touchpad mouse and a Hewitt Packard fast remote with IR Both are serial. My computer has 2 serial posrts on the back but only one device can work both dont work at the same time. I have to go into the controll pannel and enable my touch pad but when I do that my Girder controlls shuts down and Vice Versa.......What am I doing wrong?
    Check the girder settings and make sure it's on the right COM port. If it starts up with the wrong port you may have to save the new settings and reboot...Does the touchpad work in the other port? Maybe a bad port? Maybe a dead IR reciever? Make sure your OS does not think the IR reciever is a mouse.
    Just a few ideas to try and help.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      well I have narrowed it dow to bboth girder and touchpad wanted to use com1 a quick bios change and girder was set on com2. all is good there but to get my touch pad working I have to go into the controll pannel and hit refresh twice before it picks up my touchpad...kinda odd....still trying to fix this....
        Updated software/drivers maybe? Reverse the COM ports the devices are plugged into...
        Aura MR62 (F and R)
        My Current MP3s
        IamDefiler.com
          Have you checked your IRQ settings?
            I think I am a tard because I couldn't get girder to work with my Creative slim remote and receiver from compgeeks.
            I can get it to recognize the remote, but trying to figure out how to make it do something in winamp is my problem...
            Anyone care to send my a copy of their girder remote config?
            -Mario
              ok I changed the COM Ports (switched devicess) no new drivers are availble guess I have the newest one and still same problem.
              to m3rdpwr: goto www.girder.nl and download some exported groups for girder then load them you should be fine.
                Thanks man.
                They only had one for WinAmp 3 for the latest driver.
                But, I used it and modified it for WinAmp 2.x.
                I feel less like a tard now.
                Also, figuring out how to use some buttons such as on the creative remote so that I could go into mouse mode was a little tedious. Once I figured out that, it worked great.
                Thanks for the help and making me stick to it!
                -Mario
