Full size HDD...reliability concerns?
  • Full size HDD...reliability concerns?
    I'm running a WD 320GB, 5.25" desktop drive in the car...
    It's mounted vertically, as to help prevent the pickup from crashing into the platers over severe jolts...
    However, are desktop drives very fragile? Will it survive the carputer?
    Anyone else running 5.25" drives?
    5.25" is the size of standard desktop optical drives, i think you mean 3.5"...
    i had an old 40G/7200RPM maxtor drive for more than 2 years, and there were no problem with it - only overheating, but i solved it with better positioning. works in -20 and +40 celsius too, and much faster than 2.5-1.8" drives. now i swapped it to a 120G/7200 samsung one, but the 40G works well in other desktop config...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
      i've had absolutely no problem with a maxtor 80gb 3.5" for 1+ year.....and its mounted flat
        Right...3.5"
        What was I thinking? Good to hear about the reliability...
          im reading up on this as well as will be using a spare 320gb that i had lying about.
          was reading the info on top of it and the warrenty is void if it execcds 350G so i think it will be safe in my boot
          Prob 60% complete
            Unless you hit a brick wall... At 7,672.69 miles per hour and manage to stop in 1second...
            (350 * (9.8 (m / (s^2)))) * 1 sec = 7 672.69148 mph
            1.9in x 2.9in -- 47mm x 73mm
              3 years and counting on my drive mounted solid and flat, not even a stutter from it. I have long since thought but could be wrong that most of the problems cause by 3.5 drives are people using old junk drives that were probably about to quit anyway.
              Visit my site V8 Scimitar
              SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
                master of the formula at it again! i see something that and say hmm what kinda ascii anime face is that!
                Live mp3Car Facebook Chat
                  dont think ill be bothered about the HD if i did that, to be honest id be worring about the wings and halo id sprouted
                  Prob 60% complete
                    Well, depending on if the drive was mounted vertically or horizontally, then you have to take into account the direction vector and how the angle of the force on the read heads would be affected by the plasticity of the arms...
                      which would mean you would have to go even faster than that. So I should ammend it to "hit a brick wall at a minimum speed of 7672.7mph"
                        thank you... :-P
                          Yup hard drives are more durable than you or the car....
                          TruckinMP3
                          Read the FAQ!
                            Well my hdd died. I am looking at getting a SSD now as their prices are no longer ridiculous.
                            My Install
                              Right, but why did it die? I have had drives fail on the desktop and not in the car.
                              Sometimes you get a short life drive.... do not blame the car automatically.
                              Could be:
                              bad power.
                              an undetected fault when the drive was built.
                              possible but rare poor install/mount and motion related.
                              Really one of my drives survived 3 car wrecks while in use, two of the cars did not. They are generally very durable. I do not recommend testing this personally.
                              TruckinMP3
                              Read the FAQ!
