Use both PC sound output AND stock stereo?
  • Use both PC sound output AND stock stereo?
    I'm going to install a CarPC in a car, as well as aftermarket speakers and amps, but I want to keep the stock HU to reduce theft interest and provide a secondary way to play music. Is this possible? How would I wire it up? Would having 2 inputs to the amps cause problems?
    easiest way mate would be to connect it up as aux on the HU. i know with my alpine the ai-net allows a rca input ( but it would mean losing the changer unless i candind the switch) also used to use this when the ps2 was installed.
    Prob 60% complete
      Yes. As stated above, you would just run the PC's audio into the AUX input for the headunit.
      http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
      You wouldn't have two inputs to the amp(s). The only signal going to the amp(s) would come from the headunit.
      How about the Wiki?
