Power Inverter questions!
  • Power Inverter questions!
    I have a 100 watt inverter that currently is powering a powered VGA splitter. I want to add two 7 port hubs that I want to also power on the inverter. The MoBo is very picky and doesnt allow me to power anything off the 5V rail. So I wanted to use the wall adapters that came with the hubs. Is it possible I can power the VGA splitter, and both hubs off the one 100 watt inverter? How can I test?
    Here are the output stats on the inverter:
    12 VDC at 10 amps
    USB 5 VDC @ 1 amp
    The plug adapters are:
    Hub 1: 5 V at 1 amp
    Hub 2: 5 V at 1 amp
    Splitter: 9 V at 2 amps
    So technically I would be using 19 V at 4 amps, so I will be overloading the inverter?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    uh... plug them in and see if it works?
    F150 Truckputer [1.0] (coming soon!)
    Fusion Carputer [2.0]
    Fusion Carputer [1.0]
      LOL, I decided to leave the inverter alone and have it continue to power the VGA Splitter and PPC. I have a second inverter that is also a 100 watt inverter, I was going to use the USB port for Hub 1 and the plug with the hub wall adapter to power the other.
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1x Win 7 PC
