double din VGA screen
  • double din VGA screen
    Hi folks!
    I own an Seat Leon and installed a car PC in it. At first, I used a motorized 1-din screen (K301) of witch I wasn't completely satisfied (the touchscreen calibrated badly)
    Now the wole screen is broken. Now I want to install a screen that fits my double din slot. Something like the CID650 - but I only need a touch screen, a DVD slot-in drive behind it would be cool, but I definately don't need an amplifier and FM tuner.
    My question is: does something like that exists? I also see some open frame screens. Are there any frames for that kind of screens, so it will fit a standard double-din slot?
    Any help is appreciated!
    Greets,
    Tom
    hav u got the mk2 leon. ive had my mk2 since they came out and ive done alot of mods to it.i had a 1din flip out touchscreen aswell but they too small ive modded my dash again ready for a massive 12 inch touchscreen for the car pc.where did u mount ur car pc,i put mine ina box under the driving seat after i removed the air con pipes for the floor cooling theres alot of room under the seat once u do that and cut out sum insulation.if u need any advice on what screens to but and hwere from i can tell you everything u need to know and even where to get them dirt cheap u got any pics of ur install mate
      http://www.bybyte.com
      next project? subaru brz
      carpc undecided
        Originally posted by soundman98 View Post
        thats nano itx pc tho,u can get a normal mini itx pc in a double din space with dvd writer and hard rive etc, i have, so no point in buyin this
          becasue they use flash for a interactive site, it is hard for me to copy links-- here is a picture of what i was thinking of fro a double din screen--
          or
          http://www.bybyte.com/images/ABS626-...structions.pdf
          this is just a frame for a lilliput 7" screen, but fits in a double din opening.
          carpc undecided
            or
            yeah ive seen these they are neat.the thng is i had a 7 inch screen and its jsut to small for using a car pc, thats why im upgradin to about 12 inch.the small screen is ok for anything apart from when using the internet which i do so i need a bigger screen.
            what car r u putting this into ??
              i don't use the internet much in my car, so it is not a big deal. it went in a 2001 mitsubishi eclipse convertible.
              i can see how you would say it is small, as long as i use a front end, it is ok, but going into any other screen is a pain. it is easy to install, and did not require any modification to my dash, which was a huge plus for me, because i really don't want to be refabbing my dash much with this car.
              carpc undecided
                yeah sounds exactly what u wanted,how does the screen stay in the din socket tho,do u install the surround first screw it inm then does the screen attach from the front of the unit as i cant see how its attached tot he dash without falling off when hitting a big bump
                  my car came with brackets that line up perfectly, so i really just had to run to the hardware store for 4 nuts and bolts.
                  carpc undecided
