CarPC Constantly Rebooting
  • CarPC Constantly Rebooting
    Hi, I had purchased a carpc from mobile computing solutions and the link to the pc that I had purchased is: http://store.mo-co-so.com/index.php?...products_id=88
    I have read an older issue of this on the mp3car forums.
    My issue is that whenever the pc turns on it will show the bios screen, then ask me whether I want to boot the pc normally, use last known good configuration or safe mode. I have tried all of these. Once I select one of these options it will show the windows xp logo with the progress bar. The bar makes one full pass and the pauses 1/3 of the way on the next pass and just hangs there. I then stick in the xp installation disc and once the drivers and everything else is loaded it asks me to repair the installation using the recovery console or the other options. When I select repair, the pc hangs for like a split second and then reboots and starts all over again. I have also read about selecting the partition option and then fixing it that way, but when I do that it will hang for a split second and reboot again.
    I'm really at a loss when it comes to this and seem to think that it could possibly be a hardware issue, I'm not sure. Any help would be of great help. Thanks.
    try installing from a clean swipe, as for the hardware you can use something like bootable qparted to check the HD for hardware errors.
    Scion CarPC
    Bluetooth Audio Gateway Tutorial
    How to speed up boot with buried features in msconfig
      clean swipe as in reinstalling the os again? I will try qparted first.
        while you are in qparted might i suggest making a backup of the data you want to keep using an external drive
        Scion CarPC
          I was able to put the install disc in and get to the option where it gives the xp disclaimer and to proceed press F8. Once I hit F8, the pc rebooted yet again. Thats the first time I was even able to see the disclaimer screen. All that I can usually get to is the black screen where you can repair or select the other options. I am at a loss. I'm frustrated and feel like selling it, but I know car pc's are not for novice users and I am still trying to wrap my fingers around all possible workarounds for this and have not had any luck. If there are any suggestions to what may be causing this problem, I am more than welcome to suggestions. Thanks again.
            i would say before selling try doing a clean install, do you have anything on the pc that you absolutely need to save?
            Scion CarPC
              I will have to agree with "Injector".
              Format the drive if you can and do a nice clean install.
              Bad hard drive?
              2nd is this unit in the car? runnin' off the battery (engine off). In your house, workbench? I found out the my unit drains my battery in 8 to 10 minutes. Then I get stuck in a boot loop b/c It doesn't have enough power to push my PC.
              You could have a bad power supply.
              The o/s your installing is it a real oem copy or a custom made os using like nlite or tiny xp? If you make a custom o/s install becareful cause slimin' the os down you may have removed some files that xp requires. I know b/c i blue screen some installson few attempts till i get it right?
              Let me know whats going on. I'd like to see you get up and runnin'!
              Charles
                Ok, I got around to putting a bootable linux (D*** Small Linux, seriously, that is what it's called) on my flash drive. I checked it with my laptop and no problems. I plugged it in to the car pc and set the bios to allow booting usb and changed the boot order so that it would boot before the hard drive. It showed the intro screen of the linux and to press enter to continue. When I press enter it begins to show it searching for USB. An indicator starts flashing then immediately freezes. I sat there for 10 minutes with the car running and it went no further.
                But I'm wondering could a weak battery that can still start the car, not allow the pc to boot? The reason is that I think my car battery is starting to die and I had not got around to charging it or at least taking it somewhere to be checked.
                  i would say take the power supply of you desktop and plug it into the carpc and see what happens or try it with the car running, but if you just bought the carpc you might want to use your warranty.
                  Scion CarPC
                    The pc does the same thing whether the car is running or not. Will my desktop's power supply just connect to the M2-ATX power supply without any alterations to the car pc's power supply or the desktop's power supply.
                    I'm going to a local car shop and am going to have them charge my battery and/or at least inform me of the battery's voltage.
                      is not your cars battery because when the car is running the alternator charges the battery, and you don't connect the the power supply to the m2, you unplug the m2 from the mobo, hd, etc. and plug in the desktops power supply into the mobo, hd, etc
                      Scion CarPC
                        That's what I meant about connecting the car of motherboard to the desktops power supply. Should it be just as easy as connecting or are there any other steps that need to be taken?
                          No other steps.
                          You just replacing your M2 unit for desktop PSU to test.
                            Try unpluging all USB devices and hubs. At least with the linux boot disk, it sounds as if the system is unable to find a driver or did find a USB hardware problem.
                            As for the XP, I kind of suspect that a USB device may have gone bad and XP can't boot due to it.
                            If it works after unpluggin all USB, then you can reconnect one at a time to find the problem hardware.
                            The other suggestions above about your XP installation also apply.
                            • If it is custom or lite, could this be the problem.
                            • Check the power supply by swapping it for desktop PSU.
                            My first impression was a hard drive problem though. If you have a spare HDD, try installing a fresh XP on that in your carpc. And bringing it all together, is your hard drive on a USB adapter?
                            freak3dot - Computer Science Degree
                            1994 Chevy Cavalier
                            Phase 1 parts purchased.
