Standby vs. Hibernate vs. Sleep
  • Standby vs. Hibernate vs. Sleep
    Ok so far I know stand by shuts down only a few componets in a pc. Hibernate saves data to disk and then shuts down the pc and when restarted it picks up from where it left off.
    my question, is hibernate the same as s3?
    how do i enable it ( S3)..i turned it on my motherboard.
    when i hit the power button, it goes into hibernate mode. is this the same or is s3 a different state of being..lol..
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    S3 is a standby mode.
    S4 is hibernation.
    How about the Wiki?
      S4 is hibernation.
      so what happens when I enter s3 mode?
      When it goes into hibernation mode, everything shuts off....
      CarPc
      Project "Driver"
      Planning [99.9%]
        S1 - on
        S2 - sleep with more power, faster restore
        S3 - deep sleep with less power, but slower restore
        S4 - hibernation, power not required
        S5 - off
        to switch between S2 and S3, go to bios setup - but on some board, for example D201xxx there is no support for S3...
        to switch between standby S2-3 and hib S4, go to control panel > power options > advanced tab > choose one from "when i press the power button on my computer" combo box. if there is no hibernation option, check the hibernation tab if it is enabled (check if there is enough freespace on C: = size of ram). if there is no hibernation tab, check if all mobo and vga driver are installed...
        "case": Skoda Superb Elegance 1.8T
        Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
          Originally posted by FPeter View Post
          S1 - on
          S5 - off
          Thanks. My MB bios has s1 and s3. For some reason, standby does not work. It keeps telling me that a device is preventing (hid, keyboard) the computer from standing by.
          CarPc
          Project "Driver"
          Planning [99.9%]
            You have to unselect the "allow usb to wake PC from standby" option in the bios and/or the device manager.
              S0 is on
              S1 is cpu halted, cpu context/register/cache maintained
              S2 ...
              S3 is suspend to ram: cpu halted, cpu registers/contexts saved to ram
              and so on
              Now Galileo is real. Muhahahahaha :p
