need a part
  • need a part
    I was wondering if someone on these boards could make a part or know where to get it I have a automotive case and power supply the power supply has a 20 pin female connector on it and you plug a male 20 pin to 20 pin cable in it to motherboard but I have a 24 pin motherboard I would like to put in the automotive case the only problem not much space in case so doing the cable then a 20 pin to 24 pin adapter is just to much cable and I can not solder very well at all to make a 20 pin male to 24 pin male cable so if anybody could help or tell me where to find it that would be great
    thanks jason
    This will convert your 20 pin to 24 pin that you need.
    take a look at this one also. Make sure to get the correct one.
