Are There Any Differences Between Mini-ITX Motherboard and the normal one ???
  • Are There Any Differences Between Mini-ITX Motherboard and the normal one ???
    Hi ,
    Are There Any Differences Between them except the size ...?? .
    i want to use normal Motherboard but i am facing two problems :
    1-Hot weather : i don't know if it gonna hold on (some times it reaches 50 degree in my village ) .
    2- Power supply : can i just use OPUS 320W Intelligent DC-DC PSU......?
    please help .
    Mini-itx have some differences. Usually Mini-ITX boards are a laptop chipset instead of a desktop chipset. This can be good though because some newer desktop chipsets don't have integrated graphics. Sometimes the laptop chipsets will have a lower power consumption also.
    As far as power, that Opus is more then enough usually. You may be able to get by with a PSU that pulls less watts. But be careful because some mini-itx boards have non-ATX compliant power connectors.
    You should be fine with the CPU fan. If heat becomes a problem, you won't know it until it's installed. Then you can add some more cooling (better/more fans, new heatsink, better ventilation).
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
      galvitron , Thank you too much .
      I'm going to use my normal Motherboard first and see the result .
      Thank you again ^ ^ .
        No prob
        Planning:
        [----------] 100%
        Purchasing:
        [----------] 90%
        [----------] 90%
