D201GLY2 Slow POST
  • D201GLY2 Slow POST
    Hi, I am new to the forum so forgive me if this is in the wrong place. I have searched the forum and google and found no solution to the problem. I have the D201GLY2 board and am struggling with the Bios POST time and as a result it is taking too long for the machine to come out of hibernation. I get about 28 seconds overall 14 of which is all bios. Before the Intel logo screen comes up the screen flashes a couple of time various different colours and then comes up. Anyone have a solution to this. I have already tried to flash the latest bios with no change in results, I have optimised as much as i can think of, turned off Legacy USB, only boot from HDD etc. Tried a different HDD as well to see if it was having trouble initialising this one but to no avail. Any help would be appriciated.
    Also in Intel's documentation they say something about being able to Enable a Bios Rapid Boot option, however the option is not there, is there something missing or is it only on certain verions of the board?
    I have the same board and from cold boot to desktop it only takes around 15 seconds.
    How much RAM do you have? If you have a lot, hibernation can be slow.
    Want to:
      I have 1GB however using the MAXMEM I even put it down to 256 and it improved the time by 2 seconds, the boot time for windows isnt too bad, once it hits the hibernation screen its only a few seconds, its entirely the bios part of the screen. The only other thing that ocured to me that it could be is possibly the CMOS battery as the pc was in the car for a while when I was testing it for a while and it has been quite cold here recently. Short of that I dont' know what it is. Cold boot takes around 45 seconds and that is using TinyXP and Minlogon
        Forty five seconds?! Wow. I haven't done anything to the setup. Using full XP Pro, no Minlogon at all. Once I turned off legacy USB, I was very impressed with how fast it boots.
        It sounds to me like you have some kind of hardware issue. I know you've tried a new drive, but what about memory or cables?
        Want to:
          Hi, tried different RAM and tried different SATA cables as well today. I am running out of ideas now, havent managed to try the CMOS battery yet but am pretty sure that isnt where the problem lies. Any ideas about the Intel Rapid Boot option and why its not there??
            There is no way that board takes 15 seconds to boot. I bought that board just to try it out and it was dead slow at booting and coming out of hibernation.
            Compared to the Jetway 1.5GHz board, the Intel took from 5-7 seconds more to come out of hibernation. Both the Bios and the Progress bar coming out of hibernation were just too slow.
            I really don't know why manufacturers don't make a system that bypasses bios if nothing has changed.
              What sort of times were you getting from it when you tried it? from the start time to when it was into your frontend? Also what sort of time are you getting from the Jetway?
                20+ seconds using hibernation and 15 seconds with the Jetway.
                  hmm....i dont seem to be able to get anywhere near that time for some reason, will try installing a full version of XP Pro and see if there is some drivers I may have installed that is slowing it down even though I know drivers won't affect the Bios time. Other than that anyone got any other ideas?? If I changed the board what is one of the highest recommended board for fastest POST time with still enough features.
                    Those times were achieved using hibernation, not full boot. The Jetway 1.5GHz board is the fastest one that I have seen.
                      my D201GLY also stays for about 20 secs in bios / post screen before booting/de-hibernating.
                      never found a solution - deactivated all usb legacy, boot options, flashing bios.
                        there is either a lot of dreamers on here or a lot of these mobos with a problem, be it either setup or hardware, cause mine has now picked up a new symptom on top of 20 second POST. It now hangs on Intel screen till I press a key, then it progresses to resume screen where it moves about 1/2" then again hangs still I press a key. This is with a usb keyboard.
                        How can one board boot and load windows faster than aonther of the same model can pass POST?
                        My Nissan 200SX @ Silverstone
                        NOW SADLY WRITTEN OFF!
                        My Car's spec list + pics
                        Stealth CarPC fab'ing...
                          I had a D201GLYA and I also had that problem of the BIOS hanging for a while too. I never found a solution and upgraded to a core2duo board
                            it seems latest bios is 0148of Oct 08 and has fixed a fair few issues... Must re-flash
                            http://downloadmirror.intel.com/1704...easeNotes2.pdf
                              will definately check the latest version of the bios and report back any update. I have had the issue of the hanging at the Intel screen occasionally but the only times it has happened was when it was really cold outside, but when warm the issue has never occured and it reverts back to the slow POST
