This has to be an EASY one for the gurus... Relay question
  • This has to be an EASY one for the gurus... Relay question
    I am a shadetree type guy and I'm trying to find the proper relay for a project on my wife's 07 MDX.
    I need a timed relay that I can trigger with 2 + pulses and then will return a - pulse followed by the timed closure of what ever the relay is set to (about 30 seconds in this case)
    Maybe if I explain what I'm doing it will make more sense; I want to take advantage of the factory feature that closes and opens the windows when the key toggles in the driver door. I want to be able to walk away and in this sequence, using the remote, lock the vehicle (1 push) , arm the alarm (2nd push) which results in a siren chirp, and then on the third push, roll up the windows using the second siren chirp as the trigger for the relay in question.
    to activate the factory feature you have to show the car a quick turn of the key and then another turn which you hold untill the windows close.
    I have purchased DEI 528t's but it seems I need more parts or a diferent relay to start with.
    Thanks for the help; it's tough being clueless!
    Keith
    Nothing huh? Well for what it's worth I think I have to use two relays, one timed one spst. If anyone can help along further, that'd be cool.
    Keith
      Keith
      Thats simple...... http://cgi.ebay.com/4-WINDOW-ROLL-UP...742.m153.l1262. One module will roll and down 2 windows and only roll up if you have 4 windows.
      1X Ainol Novo Flame Tab
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1X 7 inch motorized Screen
      1x Win 7 PC
