what psu to choose
  • what psu to choose
    Hi getting a bit closer to finishing my build, So far I have 1.8ghz (e6300) cpu 2gb memory going to choose the intel d945fc mobo and the morex 3833 case (
    Slight concerns about the psu requirements will an M2 atx psu be sufficient I.E. I can see my self needing 1 2.5 hdd prehaps a 40 gig minimum and atleast 3 - 4 usb devices I would also like 1 external Esata drive which would have all of the media on. I like the sound of the M4 atx but not sure it will work
    is there some psu calculator that can be used that would have more or less the right componants
    ALso could you fill in the blanks with anything I might be missing to make this work (excluding monitor)
    Click on the power supply calculator in my sig...
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
      Check the Power Supply FAQs:
