Freezed carputer
  • Freezed carputer
    Hi,
    when i leave my car outside over the night and outside temperature goes below - 10C,my carputer will not work.The CPU fan runs,but no sound and no picture is visible.Has anybody same problem?
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
    try removing ram and replacing it, had a simliar problem but was that i knocked the ram
      Originally posted by BADMOPAR View Post
      Hi,
      sounds like your HD doesnt operate in the cold.
      1.9in x 2.9in -- 47mm x 73mm
        Having some cold weather issues with mine but I suspect it is the motherboard since the boards two LEDs are not lighting as they normally do on startup - will boot once it warms up a little though and only happens when it gets about five degrees or more below 0 C. Sometimes the CPU fan and system fan will run when it does not boot and other times they will not run.
        Cheap board though - researching others, suggestions would be welcome
        If anyone gives me a rev - I give them the Bird
          ^I would recommend a motherboard with solid state capacitors. I think most (if not all) of the newer Jetway's are solid state. My J7F2WE2G has been rock solid so far.
            This morning it was -20C in Toronto, psu in trunk would not let carputer boot up, warmed car up for 15min, all is well...
            Check sig for pc specs...
            Sig, smig...
            Ford Flex Toshiba Excite 7.7 Install
            CoverMess - Cool Flash Covers
            FlashFlex - Flash Components for your skinning pleasure
            Mazda Millenia, Road Runner
            YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
              This may be a stupid question, but I am finding that when my computer resumes after hibernate, when it's around 0C, my serial ports aren't starting up. (Everything else comes up fine). This causes an issue if the last thing I did was listen to HD Radio. The computer basically stalls. Windows boots, StreetDeck comes up, but the radio (serial port) doesn't resume and the process can't be killed (through task manager). I have to do a hard reboot, listen to something else, wait a few minutes for the computer to warm up, then reboot again in order for the serial port to power on.
              Is there a way to force a serial port on through windows or does it have to start up during post? Just wondering if there is a way to have the computer warm up for a few, then force the port open rather than reboot.
              My opinion is my own.
                It has to start up during post, just like legacy ps2 devices do.
                Check out my CARPC: Project Diamond Plate
                Quick Reference:
                CPU Electrical Specs
                Power Supply Calculator
                Video Connections for newbies
                Temperature Converter
                Voltage Calculator
                  That's what I thought. Thanks for the confirmation. Think I might try the serial to USB converter solution and see if that might do for winter startups.
                  If that's the only issue I have all year, I consider myself lucky.
                    It was 0 degrees F (-18 degrees C)here this morning, my system started up with no issues. One thing I have to say about Xenarc, the 700tsv is much more reliable in cold temps than the Lilli 629 was that I had before.
                      Only issue I have had on my Xenarc in a year and a half was when I broke my touch overlay trying to reposition it. Really good screen in hot or cold. If I had to "complain", it would be that the brightness goes back to 27 when I use the computer without the car running and doesn't return to 85 when I start up.
                        I've had the screen come up mirrored a few times, but that's easy enough to fix with the remote.
