how to use a USB hub
  • how to use a USB hub
    i have a problem
    i got a cheap USb 2.0 hub (4 ports) unknown company
    and when i connect it to my car pc it works (led turn on) but none
    of the stuff that connected to the hub wont work until i remove the hub
    and plug it again...
    i tried to connect the hub to a different port
    i tried to use only one device on the hub
    i tried to connect stuff to the hub after the car pc finished booting
    nothing works...
    i need to remove the hub and plug it again for everything to work
    on the hub i need to use a very low power consuming devices
    so i dont worry about the power (car2pc, small mp3 player, ect.)
    i have VIA EPIA EN15000G motherboard
    and i don't think the problem is in the hub
    i tried it on my home pc and everything is working fine
    by the way... i'm not the only one with this problem
    please help...
    The hub works fine with your desktop pc and not into your car.. have you tried using another hub (branded) just to double check?
    Electric Back Massager | Kids Remote Control Cars
      i haven't but it seems that i'm not the only one having this problem...
      maybe it's something in the BIOS
