"No video Signal" carpc is running i can hear it,
  • "No video Signal" carpc is running i can hear it,
    Hi i have recently wired up my carpc and Lilliput Gl-701 monitor.
    but i get the "no video signal" on my monitor
    i connected my home pc to the gl-701 and it worked fine just no touchscreen caus no drivers installed
    connected my LCD monitor to the carpc and it still showed no video signal.
    what could it be, any suggestions
    just to let you know that my home pc lcd had two cables, the vga and another one, i could only connect the vga, didnt think this would make a difference,
    Try unplugging/ replugging the connection from the 701 to the extension wire. make sure it is in tight.
      Are you running a processor that requires additional P4 power? A system will power up and spin the fan without it, but it will never boot.
      Greedy
      -Adj.
      Anybody who makes significantly more money than you do.
      The Hoe-Puter Worklog
      Progress (Phase one):
      Planning:
      [----------] 97.3%
      Parts Aquisition:
      [----------] 95%
      Install:
      [----------] 95%
