Wiring xenarc power/reset buttons to new headunit. Relay?
  • Wiring xenarc power/reset buttons to new headunit. Relay?
    I just got this double din touchscreen:
    http://www.mimousa.com/home.asp?dir=products&prod=2823
    It has a power and reset button built in to it with a wire lead for each the power and the reset button. I was thinking of wiring it directly to the power and reset but on the xenarc motherboard using spst relays. I am planning to use standard automotive relays that I have laying around. Anyone have this headunit and have set up suggestions? Also will the standard automotive relays work fine as I don't have much experience with mini pc relays? It's on the xenarc CP-FL9D.
