Questions on wiring and resistance for LED
  • Questions on wiring and resistance for LED
    I want to use a Wiimote instead of a mouse at home because it's more convenient where I use a projector as my computer screen. I bought a wireless Wii sensor bar and thought I'd be good to go but the thing takes 4 AA batteries for some reason just to run 6 infrared LED. Unless I keep using the on/off switch, it kills the batteries in 2 days so I want to rewire it to run off USB since it'll be sat on top of the tower case all the time. So my question is how to do the conversion. I know that AA batteries are 1.5 volts of DC power so 4 of them is 6 volts. Think there would be any issues with just soldering the +/- wires from a hacked up USB cable to a LED on each end and run them in series? Can I hurt my computer by the difference in voltages? What would be the best option? Should I go to an electronics store and by some new infrared LED?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Originally posted by Maheriano View Post
    ....to a LED on each end and run them in series?
    You want to do what!?
    Just power the thing off the 5V USB line...1V isn't going to make any difference to the device, considering it probably loses that much power on the batteries after an hour anyways!
      You NEED to read
      http://www.boonjin.com/smoothboard/i..._modifications
      There is a section for powering via USB.
        Originally posted by corvettecrazy View Post
        You NEED to read
        Powering the Wiimote. I want to power the sensor bar.
        Ampie Case
        256 MB DDR2 PC5400
        M2-ATX-HV
        2005 Honda Civic
          My fault. From what I have read about the sensor bar. You will only lose distance if the voltage is lower. If you find that you don't have enough distance for your use you may want to consider going to a 6-7 volt wall adapter.
            No worries, I soldered up everything tonight and it works great! Hacked up a USB cable, soldered the red/black wires to the battery contacts, soldered the on/off switch to the on position and plugged it into my computer. No more mouse!
            Ampie Case
            256 MB DDR2 PC5400
            M2-ATX-HV
            2005 Honda Civic
