Where can i find a Micro-itx board? (pics included)
  • Where can i find a Micro-itx board? (pics included)
    well here's my problem, i have a slimline s3100n which comes with a micro-itx (7.5"x6.4") board and a 24 pin mini power connector, my problem is that i can't find a micro-itx board to replace it with i can only find mini-itx with normal size power connector and i can't replace the power supply because of the size of the case, i found the original mobo on eBay but at $100+ for a amd borad i feel like I'm buying my third nut.
    here are some pics:
    Scion CarPC
    Bluetooth Audio Gateway Tutorial
    How to speed up boot with buried features in msconfig
    I think you'll have an easier time finding a suitable miniITX board and an adapter for the PSU connector.
    How about the Wiki?
      Yup. Either get the power adapter, or buy a DC-DC PSU (which you should do anyway).
      Using an inverter is just going to mess up the next board you buy too...
      There's PLENTY of room in there for a DC-DC PSU.
      Greedy
      -Adj.
      Anybody who makes significantly more money than you do.
      The Hoe-Puter Worklog
      Progress (Phase one):
      Planning:
      [----------] 97.3%
      Parts Aquisition:
      [----------] 95%
      Install:
      [----------] 95%
        i guess should have mentioned I'm going to use this PC in my house as a media server so no need for a DC-DC.
        Scion CarPC
          You may be subject to HP's use of a motherboard that doesn't follow any standards. They are known for manufacturing components that won't work with anything that follows accepted standards. I don't know if this board is that way or not.
          IF it only meets HP's standards, then your only option would be to get a replacement board from HP.
          How about the Wiki?
            I'd say, get a mini itx board, a new case,a nd new psu, and be done w/ it.
              i decided to trash the case, for an old one i had, and i have many PSU laying around that i can use, thanx for the help guys
              Scion CarPC
                I hope you kept the case + PSU, could bring a couple of bucks for you on ebay or something.
                Tidder
                Try RevFE
                  i threw it in my spare parts box, i might use it to replace my by carpc case down the road.
                  Scion CarPC
