Shielded antenna cable?
  • Shielded antenna cable?
    Anyone else have poor frequency problems when using their carputer with Mitch's HD radio cable and the Visteon box?
    When I used it without the PC the reception was fine, but through the PC it's bad. (I'm quite sure this is because of PC interference)
    I've searched for quality (shielded) antenna cable but found only the regular cables.
    Anyone else have reception problems or know where I can get a QUALITY antenna cable?
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    interested in an answer for this too
      I bought a super cheapo antenna off ebay just to test my Visteon with while bench testing it in my house and as long as the antenna was near a window the reception was great. Are you sure it is a reception problem or a sound interference problem?
      Did you try this? http://www.rush2112.net/phpBB3/viewt...4&p=2711#p2711
        Seems like interference, I remember that fix now, I'll have to try it.
        Thanks man!
          Well I added the rush2112 wire, seemed to help with some noise but did not improve reception by much at all.
            Most antennas aren't shielded because I believe that would defeat the purpose of them being an antenna. If you google shielding you are able to find shielding tubes that you can stick wires through. You could run this around a length of the cable so that it doesn't get interference from other cables in certain places.
            My Nearly Complete Car:
            http://www.mp3car.com/vbulletin/show...ed-car-pc.html
            Micro Control Center... Control Your Car Across the Internet
            http://www.mp3car.com/fusion-brain/1...-internet.html
            Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
            http://paulfurtado.com/
              Hmmm, that does make sense...why shield an antenna cable?
              You think that might be the problem...because reception was fine when using the Visteon box without the carPC.
                so right now your setup is:
                Antenna to visteon to mitch's cable to pc
                and when you keep everything in place but disconnect mitch's cable from the pc the radio sounds fine?
                  I had a HU before, I then got the Visteon and Mitch's cable and removed the HU.
                  So, before when I ran the HD through my HU AUX port I got many more stations (and clearer) than I do now without the HU. (and running it through the PC)
                    Hey Muldrick..did you get this figured out? I have the exact same issue.
                    Thanks...
                    Mark
                    Project completed! (almost)
                    My Truck as featured in Custom Classic Trucks magazine.
                      Nope, Kinda lost interest in carputers. Moved on to electronic cigarettes, and making my own e-cig modifications.
                      One thing I did notice (and my PC is in the trunk) is that reception improves some when I apply the brakes, and/or turn on my lights. I just don't know why.
                        Electronic cigarettes?! What'll they think of next!
                        Thanks for the reply. If I come up with a solution I'll try to post it on ALL of the threads currently discussing this issue.
                          Yeah, I'm still a nicotine addict, but at least I'm not inhaling 4000 other chemicals.
                            Not sure if you're still interested in solving your problem (the carputer, not your nicotine addiction), but check out this thread...
                            http://www.mp3car.com/vbulletin/powe...erferance.html
                            Good luck with both!
                            Mark
