hot glue ok to use?
  • hot glue ok to use?
    Well due to a fabrication/measuring error my m2 power supply is not getting mounted where I wanted it. Is it ok to use hot glue on the bottom side of the m2 power supply? Or is there a way I can mount an m2 to a bare piece of mdf without screws?
    I'm out of places to mount it now as my console is already covered.
    2004 F150 STX Heritage:
    Parts:
    ASUS E35M1-I Fusion AMD 1.6GHz DC ~$114
    Patriot 32GB SSD ~$80
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    10" Samsung touch panel - ~270
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    velcro on silicone?
    06 Silverado LBZ wants onboard everything...
      Hot glue is non-conductive, but I don't know how well it would adhere to MDF.
      Typically, hot clue needs to wrap around something to hold in-place.
      I suppose you could drill holes int eh MDF, but if you could do that, you could use screws.
      How about the Wiki?
        Hot glue does not hold up well long term in a car environment. I don't recommend using it.
          I vote industrial velcro that you would find at any home improvement store.
            If the case is made from MDF, why not screw in a few motherboard standoffs?
              Hot glue over time will start to break apart, especially in a car enviroment where there are bumps and shaking. Id use Velcro (industrial strength) or create a mounting system that uses the existing screw holes on the M2-ATX.
              1X Ainol Novo Flame Tab
              4X MK808b
              3x Perixx Touchpads
              3x 7 inch Screens
              1X 7 inch motorized Screen
              1x Win 7 PC
                As I said in the original post, the reason I cannot screw into the mdf now is because the case is already covered and I'm not comfortable drilling through the material.
                Will velcro stick to the back of the m2? It doesn't look like it would with all of the solder points back there.
                Parts:
                Kingston 4GB ~$25
                1/2" MDF - ~$15
                M2 Power Supply $85
                GPS Receiver ~ $36
                iGuidance ~100
                  That's the silicone part, my favorite is the black adhesive type.
                    Thanks, I hope to have it fully assembled by next weekend (minus the gps).
                    Parts:
                    Kingston 4GB ~$25
                    1/2" MDF - ~$15
                    M2 Power Supply $85
                    GPS Receiver ~ $36
                    iGuidance ~100
                      Be careful with the velcro idea, there is a slight chance that the adhesive on the back of the Velcro could be conductive, and create short.
                        I know you said you don't want to drill, but if you use a super tiny drill bit, whatever it is should be fine. Start with a 1/64 or 1/32 inch bit if you want and SLOWLY increase the size of the bit one step at a time.
                          I used velcro and powered it up over the weekend. Nothing shorted and it ran fine til RR locked up. It ran fine again yesterday too, I just have to sort out the shutdown instead of hibernating issue now.
                          Parts:
                          Kingston 4GB ~$25
                          1/2" MDF - ~$15
                          M2 Power Supply $85
                          GPS Receiver ~ $36
                          iGuidance ~100
