d945gclf2 won't boot
  • d945gclf2 won't boot
    Guys... I just hooked up my new motherboard, installed Windows and the motherboard's drivers, shut it down and went to bed. I come back the next day, and it will not turn on. no matter what I do, it just will not do anything. I did notice that one chip on there near the usb ports gets EXTREMELY hot right after i plug in the main ATX power connector. What in the world could have happened?
    a few questions:
    do you mean it doesn't even post?
    any beep codes?
    do the fans run?
    what power supply are you using?
      I'm talking about the fans don't even spin. I'm using a power supply from a tower I have at home for testing. It's a 20 pin, and I have it seated correctly, and I also tried it on my old MB and it boots just fine.
      So, no beeps, no fans, really hot chip right behind where the usb and lan slots. Totally odd.
        weird...
        my d945gclf2 wouldn't post, no beeps, no vga, but the fans were spinning. ruled out all the hardware by swapping parts to another pc. now i'm waiting on a new d945gclf2. hopefully yours isn't fried too
          Did you forget to plug in the P4 (2x2) power connector?
            Once. Then I turned it off, pluged it in and it booted fine... that's when I installed Windows. Now that chip gets way hot right when I plug in the main power and will not do anything.
            Maybe that one time I tried to boot it w/o that P4 connector damaged the MB like it says could happen in the manual for the MB?
              I fried mine, I am pretty sure it was by note having that connector in. The chip I fried I googled the model number and found that it was the voltage regulator for the cpu...
              Had to buy a new one, sucks.
              // 2008.5 CWP MAZDASPEED 3
              // mp3car showoff thread
              // appearance & performance mods
              // computer setup
                Have you had any problems out of your new one?
                  Nope, has been working fine/great...have been extra careful though ;-)
                  // computer setup
                    I've got a quick question for you... When the mobo is off, yet the power supply is still plugged in, do you know if that green LED by the 20-oin power connector is on all the time or does it go off? I have mine plugged into a regular desktop psu and it never goes off... even if I turn the computer off (when it was actually working that is).
                      That green light indicates the motherboard is still getting power by the power supply. The light is there to remind you that you need to unplug the power cord from your power supply if you plan on making hardware changes.
                        Oh, ok. So it doesn't really mean that the actual mobo is getting power, just that it has an available power source should the power switch be pressed.
