new to this... what is a dc-dc ?? dont understand, it is an inverter?
  • new to this... what is a dc-dc ?? dont understand, it is an inverter?
    what is dc-dc? 120v to 120v?? i don't understand?
    DC-DC lets you run your computer STRAIGHT off the cars 12v (in the US at least) electrical system. 120v interter first converts the 12v DC to ~120 AC . The computer PSU takes the 120 AC and makes it DC that the computer uses
      Inverter: Converts the 12VDC from your car's alternator/battery to standard 120VAC to run most appliances. Inverters are inefficient, noisy, large and can cause problems when used with certain PC power supplies.
      DC-DC Converter: Converts the 12VDC from your car's alternator/battery directly to the voltages required by the computer (12V, 5V, -12V, -5V). DC-DC is efficient, simple and produces no noise. It is the preferred way to go, but is usually more expensive than the inverter unless you build the DC-DC unit yourself.
      Aaron Cake
      London, Ontario, Canada
      Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
      Car: '86 Mazda RX-7 w/Basic Performance Upgrades
        DC-DC just replaces your existing power supply in your computer. Therefore you would take out your current AC-DC power supply and put in the DC-DC power supply that you would buy/build.
        Grand aMP3
        The Grand aMP3 Project
        Car: 96 Pontiac Grand Am
        Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
          Do you really have to put -12v on a AT mobo?
          If so, what is it for?
            If you want to do it right, then yes. Some video and sound cards require it, and it is required by all serial ports. You will also need -5V.
            Aaron Cake
