Laptop Screen + Touch Screen Overlay OR DIN Touchscreen Monitor - Which & Why?
  • Laptop Screen + Touch Screen Overlay OR DIN Touchscreen Monitor - Which & Why?
    I'm looking to build a carputer over the summer, probably will be using an Asus eee 701 as a base. From what i've seen so far, a Double-DIN Touch Screen monitor is over 100, which is probably more than the PC will cost me.
    At the same time, I could use the 7" screen that comes with the 701 (should fit in an Double DIN slot fine), and then use a touchscreen overlay - which I can get for about 25.
    I understand that one requires a few mods to get working - but I honestly can't see why I need to spend so much?
    Also - if I were to use a 9" Acer Aspire One instead, would I be able to fit the 9" screen (overlay is a similar price) in the double DIN slot?
    Personally, I think that a touchscreen monitor would be much nicer. The only downside to a overlay that I can think of is that it may not work as nicely as a prebuilt one. What you could always do is try the overlay first and see if you like it. About the 9" screen in a double din, I highly doubt it. A double din is 100mm high by 180mm wide. (Basically 4" by 7")
    -SwiftDeath
      If by 701 you mean lilliput EBY-701, it is a touch screen.
      My Nearly Complete Car:
      http://www.mp3car.com/vbulletin/show...ed-car-pc.html
      Micro Control Center... Control Your Car Across the Internet
      http://www.mp3car.com/fusion-brain/1...-internet.html
      Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
      http://paulfurtado.com/
        No, I mean the Asus EEE 701.
