**Please help!! disk drive/windows issue
  • **Please help!! disk drive/windows issue
    Thank you for looking!
    I have an external USB DVD drive (see below) that I'm having issues with and can find no solution to the problem. Even worse, is that the problem is intermittent and I can find absolutely no pattern correlating to the issue. Here are the steps leading up until now:
    1. First plugged in the drive; worked and formatted windows
    2. Loaded Included drivers disk from Intel for the mobo
    3. Updated windows via windows update (look, a palindrome!)
    4. Installed RR and USB wireless network adapter (everything still working fine)
    5. One day, the drive is no longer recognized.
    6. 12" USB cable and separate 5V power (verified with DMM)
    7. Drive works 100% on other computers
    8. Everything else works fine on carputer
    9. Drive SHOWS UP IN BIOS but not explorer.exe
    10. Uninstalled/rebooted all USB controllers/ root hubs (no change)
    11. Drive has no separate drivers: plug n play
    Based on the fact that the drive works on other computers and that it shows up in the BIOS on the carputer, I am assuming its a software issue (with windows?).
    More weird info:
    Sometimes, when only using the USB power, the drive will show up. BUT, when a disk is inserted and the drive spins up, nothing happens, and sometimes the drive will not show up after doing this. I'm confident the drive has enough power. I really think its a Windows issue.
    can anybody help? I'm about ready to give up.
    System:
    D945GCLF2 mobo
    toshiba 160GB HDD
    2GB RAM
    M2-ATX
    drive: Teac DW-224SL-R
    Bought it all assembled from Mo-Co-So.com
    when the drive is not recognized, is the drive still getting a steady 5v supply, have you checked it with a volt meter for power drops under load? when you use it on other pcs are you using the same power means or something different?
    Scion CarPC
    Bluetooth Audio Gateway Tutorial
    How to speed up boot with buried features in msconfig
      When on other computers, I don't even need to use additional power beyond USB for it to work (only a 12" cord). Yes, I have checked and the 5V power is consistent.
        is it intermittent or does it happen on a specific action occurs?
        Scion CarPC
          Completely intermittent. I can't figure out one single event that correlates with this problem.
            have you tried a different usb port? or using a thumb drive in the port that's causing issues and checking if the problem is still there?
            Scion CarPC
              Yea, I've tried using it on other ports and it still does the same thing. Likewise, all my other USB devices work with any of the ports. I do not have a secondary USB drive I could try either.
              Is these some sort of thing Windows uses to label a USB device? Maybe its trying to label it as a mass storage device instead of a drive; is that possible?
                Corrupt USB enumeration in your registry, maybe just need to do some registry cleanup. ...
                * Device Manager - Uninstall USB Root Hubs
                * Regedit HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB
                * Clear out all corresponding keys
                  The +5 VDC is constant on any USB port I beleive. I would sugest uninstalling the device drivers while under Windows 'Safe Mode' then re-installing them under Windows 'Normal Mode'. The voltmeter idea was not bad. You could use it to test the supply voltage from the port. You could have a bad motherboard. Good luck!
                    i was thinking that he might be using the usb ports that connect to headers on the mobo, because i've seen some cases that have as many as 3 ports but only 1 header connector to the mobo.
                    Scion CarPC
                      i just thought of something if you want to rule out software from hardware try using a live environment, if it fails in the live environment then it hardware if it doesn't the it's software.
                      here's some instructions:
                      http://www.tacktech.com/display.cfm?ttid=359
                      or if you're familiar with Linux you can download a prebuilt one. (MODs it's free under GPL licence, i don't want another hit for warez)
                      Scion CarPC
                        Thanks for the help everyone! I will try these suggestions and report back tomorrow. I really hope its not the motherboard. Not because I'm out of my warranty period, but because I'm a total idiot and redoing everything would make me want to jump off a bridge!
                        Injector: Are you telling me to (a) create this disk on a different computer, then boot with the problem drive or (b) attempt to create the disk using the faulty drive on the working computer (my desktop which it always works with).
                          Can you explain how to "clear out all corresponding keys"? There is a multitude of subfolders under that path.
                          **Also, I don't know if this helps or not (think it will):
                          The cd/dvd drive shows up as a folder with this path:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\E num\USBSTOR\CdRom&Ven_TEAC&Prod_DW-224SL-R&Rev_1.08
                          that folder had 6 subfolders. all 6 have subfolders "device parameters" and "logconf" but the first subfolder of the above TEAC folder also has "control" too.
                          Is my computer thinking the cd drive is a mass storage device? should it be?
                            First try this: http://support.microsoft.com/?kbid=314060
                            And if it does not solve your problem then;
                            Export your registry to a file, remove the subfolders in the following registry keys. If all else files you can double click on the registry file to add the items back in.
                            HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB Printers
                            HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB Storage
                              just be careful you don't remote the upper Enum folder, i did it after being fed up with bad drivers but i made a backup of the removed keys thinking i would just be able to restore them if anything went wrong, man was i wrong it removed all my drivers including mouse and keyboard which left me with literally no control of the pc, i had to boot in my Linux partition to fix the registry.
                              Scion CarPC
