Analogue inputs into CarPC - eg Batt Volts?
  • Analogue inputs into CarPC - eg Batt Volts?
    Hi Guys,
    How do I get analogue data into the CarPC setup? I'm planning out the system now so not yet decided on the hardware but I am unlikely to put in an OBDII link since I am not really interested in most of this data.
    I am, however, interested in battery voltage for the primary and secondary batteries and would prefer these to appear on the screen instead of on dedicated instruments.
    For an industrial setup I would do this through a PLC or RTU but this seems completely overkill just to get some basic levels into a PC.
    Is there a simple ADC with serial output option I could use? How do you guys do it, especially for systems with a second battery that isn't visible through the OBDII link?
    fusion brain or phidgets can easyly do this plus more...
      We build custom boards based on the Rabbit Semiconductor SmartStar system. It's WAY overkill for this.
      http://www.laurels.com/transmitters-4-20.htm
      Modbus interface gets you a couple analogs.
      A few more:
      http://www.superlogics.com/serial-da...ystems/115.htm
      http://www.omega.com/toc_asp/subsect...n=D01&book=DAS
      http://www.iotech.com/?mc=5GGL
        Thanks for that - those Phidgets are *exactly* what I have been looking for but for some reason the old google results weren't coming up with the goods...
        Cheers
          Try Fusion Brain - http://www.mp3car.com/vbulletin/fusion-brain/
