Voompc-2 Molex Connector
  • Voompc-2 Molex Connector
    Hi, I was trying to add more pins to the connector to try and run a 12v and 5v line out of the case. The manual says www.digikey.com has all the connectors and pins that I'll need and that the connector is a "mini-fit jr" type.
    Now, I went here:
    http://search.digikey.com/scripts/Dk...=mini-fit%20jr
    and I was going to buy the pins and sockets, but there are two types of contact finish and four types of series listed. Which ones do I buy?
    I'm having the same interrogations as you are. After a lot of researches, I found that part that matches exactly the connector on the VoomPC 2.
    However, I have a couple more questions before ordering:
    Will I have to buy separate terminals and wire and solder it myself? Is there a place where I can buy complete connectors with terminals and a couple of inches of wire so I can just solder the wires I need on my cables?
    Also, is there any counter-indication about leaving a wire to the battery unplugged? I want to be able to plug/unplug my carputer easily so I can take it out for extensive updates or during winter. I was planning to wire it directly to the battery as explained here and finish the wire with a molex-connector. Can there be any problem of leaving the cable hooked but with nothing plugged at the end?
      Well, I gave up on trying to find the correct pins and terminals. Instead I popped off the cd drive cover and routed my wires through there.
      So now I've got on/off switch, 12v, 5v, and amp remote turn on wires running out of the cd drive.
        Did you try live chat with digi key?
        FAQ to the FAQ - Great Starting Point
        My 2006 Honda Accord Carputer - Work In Progress
        My 1997 Chrysler Concorde Carputer - Died
          Ack, I didn't see a live chat button. Oh well, running separate wires out for everything will be easier for installing anyways I think.
