Making fan come on when CPU goes above 55 degrees?
  • Making fan come on when CPU goes above 55 degrees?
    Hi,
    I just purchased a Server case fan thinking that I wouldn't hear it as it would be in my boot. I was very wrong. It is very load.
    So is there a way to keep it turned of or at low speeds until it reaches a certain temperature, then it runs at high speed until temperature is down again.
    JM
    Car: Ford Focus
    Currently stock setup. Trying to decide on the best setup for me.
    Just hook it into one of the fan connector pins on your motherboard. They do temperature and speed control.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      I've done that, it is still running at about 4000rpm.
      Car: Ford Focus
        It could be that your mobo doesn't do automatic temperature/fan control. Try this out.
        http://www.almico.com/speedfan.php
        EDIT: A link to the fan you bought wouldn't hurt either.
        Tidder
        Try RevFE
          haha, good ol' speedfan. I actually do have this, I just use it to monitor stuff XD. Never really understood how to control fans with it though, but I well def give it tommorow before I drive to work :P
          Car: Ford Focus
            lol, didn't the name clue you in as to what it might do? Ahh computer people... so silly.
            Tidder
            Try RevFE
              haha, I'm not quite that stupid, I do know what it's main purpose is. It is also a good accurate, lightweight way to monitor sensors.
              Car: Ford Focus
                Yeah, that's pretty much all I use it for these days as well. What kind of fan did you buy and what motherboard do you have?
                Tidder
                Try RevFE
                  GA-8S661FXM-775 motherboad
                  :http://www.gigabyte.com.tw/Products/...ProductID=1842
                  120mm Delta Server Case Fan Focussed Flow FFB1212EHE 4000rpm Ball Bearing
                  :http://www.scan.co.uk/Products/120mm...m-Ball-Bearing
                  very noisey XD
                  Car: Ford Focus
                    According to the specs on that link, that fan does not have the 3rd wire required to sense the RPM. Does it have 2 wires or 3?
                    EDIT: And it looks like there are multiple versions of this fan. Does yours have one connector or 2? Looks like regardless of which version you have, they should have 3 wires total, red, black, and blue (pictures show blue, weird). Yes?
                    Tidder
                    Try RevFE
                      Gah that fan is INSANE! 24 watts? jeeze...
                      Tidder
                      Try RevFE
                        It has three wires, red, black and white and one connector.
                        Haha, yup it is immensely powerful, but with great power, comes great noise levels!!!!
                        Car: Ford Focus
                          Insane... let me know if speedfan ends up being able to control it, I think I'd like to get one too. At 25w though, I'd almost think that a lil ol' mobo fan header wouldn't supply enough juice to it... that's a little over 2a.
                          Tidder
                          Try RevFE
                            Will do, I'll post back late tommorow.
                            Car: Ford Focus
                              Would you happen to have a fusion brain?
