SpaceNavigator + RBC9 driver + Windows 7 issues
  • SpaceNavigator + RBC9 driver + Windows 7 issues
    Hi guys,
    I'm in the middle of my carpc project, and while I have most things going correctly, this one has me baffled. I'm using the D945GCLF2 Atom board (which is working perfectly btw), and I have Windows 7 RTM build (7600) installed. I have the Spacenavigator PE edition connected to it.
    Now, when I use the SN with the stock drivers (which of course doesn't help me as such, since I need the functionality of the RBC9 drivers), the SN works great, on a cold boot, resume after S3 sleep, and resume after hibernation. When I use the RBC9 drivers, and I have them installed correctly as such, since everything works (and works GREAT), the SN works fine on a cold boot, but the system does not detect the SN after a resume from S3 or hibernation.
    I have tried it on EVERY USB port in the system (including internal and external) as such, although the issue is not the USB ports, since the stock driver works perfectly as such.
    Has anybody else faced the same issues with the RBC9 drivers? Is it because of Windows 7 and compatibility? Is RBC9 still working on his drivers? (which I doubt, since I haven't seen any updated drivers. I guess 3DConnexion got to him...) Any ideas?
    On a related note, while configuring the RBC9 drivers for my usage, it has a few issues when it needs to send a key combination, like Ctrl-Shift-S for e.g. Is the right way to do that, is to have 3 individual binds? One for Ctrl and Shift key hold, one for S key press, and then one for Ctrl and Shift release?
    Please help, since this is the last stumbling block in project!
    Appreciate any input.
    most likely i need to wai for new moded drivers as my best guess would be that mod was done for old dtivers. First time I staryed playin w/ SP (SN as u called it) it was on XP so respectively all mods i ever build where on ex too.
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
      SOLVED. You MUST use the "v2" drivers. If your driver doesn't say v2 at the end, you have an older driver. Works perfectly in Windows 7 32 bit. Haven't tested with 64 bit (and don't need to, for the carPC).
        where to found v2 drivers?
        Huawei Mediapad 7" (1280x800 IPS) | Carnetix P2140
        My last update http://www.mp3car.com/show-off-your-...t-version.html
          http://www.eagle-i.us/HONS/
            many thanks
            I try to replace exe file for update driver but windows 7 return an error;
            I found RBC9-SpaceNav.sys file in directory; i have to update the sys file aslo?
            how to?
              Originally posted by aziodale View Post
              many thanks
              how to?
              Uninstall the USB device (the HID device) from Device Manager.
              When Windows says "You are about to uninstall...." and provides a checkbox that says "delete driver as well..", check the box, and uninstall the device.
              Unplug the SN.
              Extract install files from the driver package that you downloaded from the site above, somewhere on your computer
              Plug in the SN again - Let Windows install the default drivers.
              Go to device manager and right click the new HID device and select "update drivers". Point it to the location where you extracted the files.
              Once done, reboot.
              You're done.
                Unplug the SN.
                Once done, reboot.
                You're done.
                Yesssssssssssssssssssssssssssss
                thanks
                  I found in the RBC9 archive over drivers aslo sources;
                  are public?
                  may i modify interface for 800x480 resolution?
                    are public?
                    If the source is out there....it's for you to play with.
                      Ok
                      all done
                      where upload new exe file?
                      I did :-)
                      http://www.mp3car.com/vbulletin/down...?do=file&id=84
                        I don't seem to be able to download the 800x480 version, no permission... Could you upload it to rapidshare or similar? Thanks.
                        My install: http://www.mp3car.com/vbulletin/show...03-2005-a.html
                          Sorry but i only upload to Mp3Car forum, i d'ont know why;
                          I think we should ask why administrators.
                          try this
                          http://rapidshare.com/files/29448626...ceNav.rar.html
                            Thanks a lot !!
