my wrestle with alternator noise.
  • my wrestle with alternator noise.
    I am about to give up. I have read extensively the tips and notes all over this forum. This is my last attempt at getting help. The amount of alternator noise that goes through my speakers is actually imbaressing. I'll show off my system, but get "But what's that high pitched whine that gets louder when you step on the gas?".
    Things I have tryed.
    -Grounding. I have grounded the computer case, the powersupply (in several spots), the amp from which I draw power from (in several spots). Helps, but very little.
    -I bought a dc/dc PSU just for this reason. I thought it would take ALL the alternator noise away when I got rid of my inverter. When I replaced it with the PSU, the noise stayed EXACTLY the same.
    -Ground Loop Islolator. I've tryed placing as the last thing before the rca's reach my head unit. It cuts it down, but only a little. The high pitched whine can still be heard threw the softer songs. I've even tryed putting two in parrellel! The thing also gobbles up lower frequencies in the music. Something that does hardly any difference and takes lower frequences out is not worth my time.
    -Grounding the RCA cables before they go into the head unit. Trying this actually made the noise get LOUDER!
    -Shielded Cable. I went to radioshack and spent $50 on their best gold plated RCA cable they have. Made no difference. (that made me angry!)
    -Switching sides. I orignally had my power and audio running along the same side, and I seperated the two, power on the left, audio on the right. This helped, but apparently not enough.
    -Lowering the volume on the carputer and raising it on my HU. while this works, it also cuts all frequencies in half, even when blasting. sounds like am radio.
    As you can see, im about to go completely insane with this. I can't listen to my music for more than an hour at a time, the ringing gives me a headache. Movies? forget it, its so loud during movies its not even worth it. Please tell me there's hope. There has to be. please!
    Grand AMplifier Project 1.0:
    http://drive.to/cliffsgrandamgt/
    http://www.astallaslions.com/carmp3/
    -Eden 800 mini-itx motherboard
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    -PB Remote /w Girder
    -Media Engine & Windows XP
    -Playstation II also added
    -Steering Wheel Buttons modified for Control.
    i'll take a crack at this..........
    1) is your computer in the trunk with the pwrsupply? i ask this because when you run your RCA cables from the back of the car to the front headunit under the carpet, some people just put all the wires in a loom with the pwr wire. This causes some interferance with the RCA cables. Make sure you run your pwr wire on one side of the car and the speaker wires on the other side.
    2) I take it that without the computer setup connected you don't have the wine and the stereo was working okay?
    3) Have you checked ALL your RCA connections? the reason i ask is because i made my own and with one of them i soldered the connector on sloppy and it was causing a wine only when the car was running.
    Hope this might help.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
      Yes it is in the trunk with the powersupply, but have seperated the power on one side and RCA on the other side of the car.
      The stereo when playing CDs and Radio alone have no wine.
      I have double checked ALL RCA connections to be connected fully numerous times.
      -5.6 NTSC TFT-LCD
      -80 gig hard drive
      -128 MB RAM
      -MPBS1 DC-DC PSU
        is everything grounded to the same spot? i am under the impression that this can make a difference.
          Actually I have experimented with this, and found that I had BETTER results from grounding to different spots, as much sense as that might not make. I'll give that another try though.
          -5.6 NTSC TFT-LCD
          -80 gig hard drive
          -128 MB RAM
          -MPBS1 DC-DC PSU
            in your audio cables---try making up a short cable with only the positive wires--no ground--after the computer and before your amp. this might work! i used to do this a lot when i was an installer.
            99.9% complete.
            http://www.cardomain.com/ride/212327
              im not sure what you mean, can you explain this further?
              -5.6 NTSC TFT-LCD
              -80 gig hard drive
              -128 MB RAM
              -MPBS1 DC-DC PSU
                if you throw in a regular head unit do you still get the same problem??? this would let you know whether it is your computer or something else causing the problem. i would also try running a better cable from your battery to chassis and alternator to battery. while it may not help this specific problem, it is always a good thing to do when you add a stereo to a car..
                only things i can think of, as it seems you have tried everything that i would have
                later,
                nathan
                  stinkynathan,
                  Cliff,
                  So you're sure it's the alternator then? Have you tried using the carputer in with the ignition in accessory mode (so the engine isn't on)? Would a cap help to smooth out the power? But I guess that's not a problem, especially if the Opus didn't help. Are you using the right wire sizes so you're not getting a voltage drop? Sorry... you've tried everything that I would have done.
                  No Carputer YET.
                  A car I'm designing...
                    he's using jeff's supply, not an Opus
                    aka Kumaneko
                    "Don't make me moderate your ***!"
                    Maxima of Doom - project thread - photo gallery
                    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
                    Real computer hackers use a rotary cutting tool on their motherboard.
                      Just to add my 2 pence, Im on a CRX forum, a lot of the folks recently upgraded their stock ground cables:
                      Battery to body,
                      Battery to engine,
                      Engine to body,
                      Throttle body (think injectors) to body,
                      It seems to have a made a big difference for most people. The stock ground cable isnt exactly huge, and in an older car the cable isnt going to be its best.
                      This "upgrade" also improved the brightness of both interior and exterior lighting.
                      Just some 8awg and ring connectors all round.
                      I plan to use 4awg for the battery to body.
                      Dave
                        make up a short "audio out" cable from your computer only using the shielded wire not the ground. this might remove the ground loop.
                        99.9% complete.
                          Tried replacing the alternator? Could be a bad rectifier.
                            Originally posted by Filip
                            stinkynathan,
                            Cliff,
                            When just the ignition is on accessroy mode there is no alternator noise. I'm sure it's the alternator because it gets louder and gradually softer when I hit the gas, the noise coincides with the RPMs of the engine perfectly.
                            -5.6 NTSC TFT-LCD
                            -80 gig hard drive
                            -128 MB RAM
                            -MPBS1 DC-DC PSU
                              Battery to body,
                              Battery to engine,
                              Engine to body,
                              Dave
                              That sounds like a good idea, I just have to find places in the engine bay where those grounds are. Also id have to buy all that expensive wire
                              -5.6 NTSC TFT-LCD
                              -80 gig hard drive
                              -128 MB RAM
                              -MPBS1 DC-DC PSU
