those using EPIA VIA 800 mobo
  • those using EPIA VIA 800 mobo
    Hi, for those using th EPIA VIA 800 motherboard.
    I got everything up and running, installed win2000 pro. And when I install the 4-1 drivers. That goes fine and I restart. But then I cant install anything else. I get an error message "can not execute .. error at 000000x8..." and then "This is not a Win32 application"
    Anyone get these messages?
    I cant get anything running because of this. The audio, video, lan, or even upgrade OS.
    Mine needs to be updated.
    Try un-installing from safe mode and reboot.
    If all looks fine, try to re-install.
    Make sure you have the latest Hyperion┐ drivers.
    If you were using the latest drivers, download an older set...
    -Mario
      try the memtest86 to test your ram
      Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
